Page 5 of 18 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 171
Thread: Installing the V8 Software
  1. #41
    Sep 2006
    Yes, the firmware needs to match the boot block.
    So if you have V2.05.xx you need firmware 2.05.xx
    Then, once the boot block and firmware are both at V2.05.xx you can update the boot block to V2.07.xx, then the firmware again to V2.07.xx
    There is a document that you should read:
    Start->All Programs->EFILive->V8->Documents->Upgrading Firmware.
    That document explains all the steps.
    Yes, that's the document I've been following. I got to step 6 on page 7 when all went bad. So I have boot block V2.05.08 and need firmware v2.05.21 but cannot make this happen for some reason.
  2. #42
    Sep 2006
    Step 4 I get message "Connected device is not responding". Status of Flashscan V2 is ""not connected". I've tried everything to get a connection, closing and opening program, disconnecting and reconnecting USB cable. I cannot get past step 4.
  3. #43
    Can you try re-installing the USB drivers?
    Disconnect FlashScan
    Use the program: Start->All Programs->EFILive->V8->EFILive USB Manager.
    To run it right click on it and select "Run as Administrator"
    Then select the [Install USB V2.02.04] option.
    Reconnect FlashScan.
    Re-start EFILive_HAPI and try again.
    If it still fails, select the "F8: Trace" tab page and click on [Save Trace].
    Save the file and email it to me at paul@efilive.com
  4. #44
    Sep 2006
    Still no response, email sent.
  5. #45
    Dec 2010
    Having problems installing a tune on my LBZ.
    Tune is setup in V7.5.
    Ready to do the install, hit Start...
    Get prompted with "Flash Scan/ Auto Cal not compatible" download the latest V8 and use "EFI Live HAPI".
    Downloaded the latest version.
    Double click on HAPI nothing happens- but try to reinstall V8 and get prompeted with HAPI is currently running.
    Try to install the tune... and again the samething happens
  6. #46
    When you start "EFILive HAPI" (aka The EFILive Control Panel) a small FlashScan icon will appear in the system tray at the end of the start menu bar (near the clock).
    Click on the FlashScan icon to open up the EFILive Control Panel window.
    Select the Firmware tab page and update your firmware.
  7. #47
    Dec 2010
    Updated the bootblock and firmware.
    Do I need to re-register?
    If I do. What info will I need?
    And how will I go about doing this?
    Thank you
    Mack
  8. #48
    Mack, you should be ok (if you already registered).
  9. #49
    Oct 2004
    Should be no need to re-register the software. If you do (for some reason) then you'll need the information from your blue registration card. If you no longer have that available email me (suport@efilive.com) with your Serial Number and Auth Code (found as per this guide)
    Andrew
    EFILive Crew
  10. #50
    Dec 2010
    Found my blue card, just incase.
    Now after the update I tried to install the tune and do not have the option to flash (everything is grayed out)
    What else do I need to do?
    I appologize Gents, I am new to this.
    Thank you
  1. Installing the V7.5 Software
    Last Post: February 9th, 2021, 11:28 AM
  2. Installing new ECM - What to expect??
    By juscruzn in forum Duramax LLY
    Last Post: February 1st, 2010, 09:46 AM
  3. installing drivers for new 7.5.5 v2
    By Adam Calley in forum Gen III V8 Specific
    Last Post: April 15th, 2009, 08:12 AM
  4. Installing new firmware
    By black346 in forum FlashScan V2
    Last Post: March 29th, 2007, 09:02 AM
  5. Installing Custom OS
    By oztracktuning in forum Custom Operating Systems
    Last Post: April 27th, 2006, 09:58 PM
