Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 129
Thread: Public release, March 29, 2012
    Was the GM.EOPS PID removed from this release?
    No its still there same as its always been.
    Unless the second digit of the VIN is "G" and the fourth is "F", then the EOPS PID won't show up (i.e. for F-Bodies).
    F-Body controllers report the EOPS PID as valid, but there was no oil pressure sender to provide that PID with valid data on the F Bodies.
    Dec 2006
    2012 Cruze is in there, but, I forgot to add two important torque tables, without them it won't make more power than stock, however both the 2012 OS's have had the tables added today and will get in to a release ASAP.
    Thank you!!! I know a LOT of people will be very pleased with this, looking forward to that correction being released soon, please let us know.
    8.7 @ 84 (1/8 mile) bolt-ons
    Default GM.EOPS and CALC.EOPS
    Highlander,
    if you want that pid go File->Enter VIN and enter the VIN from a same year Corvette...
    e.g. I change the first 4 digits of the VIN to 1G1Y... this makes the pid GM.EOPS show up which then allows CALC.EOPS to become valid;
    Paul said that the 2nd digit has to be G and the 4th digit has to be Y (and not F)... I think that's what he said.
    [ of course, in an F-car you would have to wire up an EOPS to the PCM to get meaningful data from those pids ]
    Quote Originally Posted by Boost View Post
    Yeah, I had a call from a shop over here who had a 2012 Cruze strapped on the dyno, it was making no more power than stock no matter what....oops, the two tables cured the problem.
    Member scottcmb's Avatar
    Aug 2011
    Cant remote flash a tune into my car with my Flash scan V2........the file has been converted to a CTZ but when i got to flash it in with my v2 IT COMES UP WITH $050B ERROR and says its not compatible with the current firmware.........but i have updated the V2 with the latest firmware in the new release as well as the latest bootblock.........what have i done wrong?
    Cheers Scotty
    Quote Originally Posted by scottcmb View Post
    Cheers Scotty
    You need to re-copy all the support files (*.obj, *.bix etc) onto the V2.
    Connect up the V2, open the [F5: BBX] tab page in the V8 software, click [Read] to get the current V2 config, then click [Program] to update that same config back into the V2.
    It updates the files based on dates, sometimes due to date/time differences between here and where you are it may not work in the first 24 hours after a release.
    So you can force it by clicking the little black triangle on the [Program] button and selecting [Program All Required Data (slower)]. It will take longer but all files will be updated regardless of date/time stamps.
    Ha, I forgot you're just down in Tokoroa
    Dec 2006
    Haha, that's nice, well like I said I anxiously anticipate the correct release, please do let us know as soon as it's available! Thanks again!!!
  9. #19
    Paul hinted for Sunday, but if you want to proceed then use this release and I can send you the .calz file with the updates, it's all done.
  10. #20
    Dec 2006
    Oh pleeease would you Ross? I didn't want to ask but I'd GREATLY appreciate it!
  1. EFILive Class in Kinder LA March 3-4th 2012, Duramax and Cummins
    By dansdieselp in forum General (Diesel)
    Last Post: January 8th, 2012, 01:38 PM
  2. Replies: 0
    Last Post: January 7th, 2012, 04:01 PM
  3. Public Release June 03, 2011
    Last Post: July 9th, 2011, 07:59 AM
