36# depending on flow. Installing now. Guessing @ need to fix injector tables before going forward with tune
Measure rail pressure, see spreadsheet here (is your FPR vacuum-referenced or unreferenced): Calculating-Injector-Flow-rate
( on the spreadsheet use the EFILive tab )
Cool thanks
In da house Let us know how it goes after the injectors are in...
GM EFI Tuner
02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
installing now... just got back from junkyard trying to yank a vlsd off an inifinity that drops right into my car. had it all the way unbolted except for drive shaft yolk nuts... they ended up rounding off after fighting it for 2 hours...
couldnt get a closed in wrench of them... open end and even flare just rounded them . correct size too. gonna go back tomorrow morning with a sawzall and cut the bolts off.
ok im learning the spread sheet, but also found the flow tables for these injectors since they are already available
edit im also following this thread. these are the exact injectors i have
http://forum.efilive.com/showthread....868&highlight=
im using mr.prick "bosch 0280155868" script" for my tables. this should be correct. also he mentions something about a cax file in that thread. but i have no clue yet what that is and i see im not using an efi live custom operating system. . should i?
quick question. if i follow these tables on b4005 in his .txt for small pulse width adjustment he states
0,0.000,0,3.951
on the top of the text. i get later when you scroll down and he has the full txt to copy and paste into your columns and rows. but what is he talking about at the top?
ok i changed my tables per mr.prick's .txt file on these exact injectors and.... car wont start lol. it will maybe sputter for split second. then nothing hahaha
this is my updated tune with the injector info changed. if im doing something wrong my mistake. still learning this stuff
If you copy the cax file matching your OS (12212156) to the folder Program Files\EFILive\V7.5\Calibrations then you will see a new table in the tunetool (B9021)...
retrieve Cax B from the zip file in post #12 here need-B9021-for-01250003 and rename it to 12212156.cax and copy to that folder.
