Results 21 to 30 of 42
Thread: BBL PIDs V2
  1. #21
    Sep 2008
    Quote Originally Posted by Laychut View Post
    Hi,
    is there a way of using calc PIDS while Black Box Logging?
    Laychut
    Yes there is. I haven't got EFILive on this computer, but look on the V8 interface next to the 'PID Menu Items' box and you'll see a V7 icon and a single gear icon. If I recall correctly, select the V7 icon and you can input Calc.pids you wish to be monitored during logging.
    Hope that helps.
    cheers
    HSV Senator 300 - the Classy C4B...
    C4B - ETP215s 62cc, Comp 215/223 .601/.609 @111+3, Manley 8.050" 5/16" P/R, Morel Link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster chain, OTRCAI, T-56 - RipShift, HydraTrak 3.91:1, DiFilippo 1.75" 4-1s, twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune.
    308rwkW(413rwhp)
  2. #22
    When you specify the calc pids in BBL, they will be automatically selected when you open the log in the V7 scantool.
  3. #23
    Member Laychut's Avatar
    Jan 2011
    Hi,
    In V7 i can see the calc pids. How do I get them into V8?
    cheers,
    Laychut
    Going places no one else dares to Go!
    60 Series Landcruiser, GenIII LS1 5.7, 4L60E Trans, 4" Stainless Snorkel
    4" Lift, 35 x 12.5 BF Goodrich Mud Terrains
  4. #24
    They don't show up in V8... you have to copy/paste the pid name from V7 (or otherwise manually enter it) into V8.
  5. #25
    Jan 2011
    Hi Joecar,
    how and where do I paste them into V8. V8 does not seem to have the same User configuration file as V7.
    Laychut
  6. #26
    Jan 2011
    Hi,
    I think I have just found it. When selecting the PIDs in V8, you click on the V7 button and add the PIDs without the calc. in front of it.
    Am I correct?
    Laychut
  7. #27
    Yes, that is correct.
  8. #28
    Jan 2011
    Thanks!
  9. #29
    Jan 2011
    Hi,
    I would like to get some idea how the experienced EFI Live users manage their Calc.PID file.
    Do you just keep adding to it so it gets bigger and bigger or do you have seperate ones for each type of tuning that you replace when needed?
    Laychut
  10. #30
    I use the most recent Calc.VET/Calc.MAFT file (see attached), and just add to it as needed...
    Before I delete something from it, I save a renamed copy of it in a subfolder.
    It would be nice for the scantool to be able to read multiple calc_pids.txt files.
  1. Imperial pids for BBL?
    By thunderstruck507 in forum Black Box Logging
    Last Post: February 9th, 2010, 04:04 PM
  2. BBL Pids???'s
    By GAMEOVER in forum Black Box Logging
    Last Post: March 16th, 2009, 10:37 AM
  3. Bbl Pids?
    By Beer99C5 in forum FlashScan V2 BB Logging
    Last Post: July 31st, 2008, 07:57 AM
  4. BBL PIDs
    By mr.prick in forum FlashScan V2 BB Logging
    Last Post: July 4th, 2008, 04:26 PM
