Results 1 to 10 of 16
Thread: E67 and VSS - Removal of the TCM for manual transmission
    Aug 2006
    Default E67 and VSS - Removal of the TCM for manual transmission
    I'm working with a 2008 Trailblazer SS E67 and want to use ECM C3 pin 66 and C3 pin 67 for VSS high and VSS low because of a manual transmission application. While this looks good on paper, I'm not seeing a VSS signal in the scan tool.
    Has anyone eliminated the T42 (which has a VSS output to ECM C3 66), used a manual transmission, and a VSS signal directly to the ECM?
    This is not yet installed in a vehicle, but being tested on the bench.
    24x LS1 PCM on Early Small-Block Chevy and LT1/LT4
    http://www.eficonnection.com
    Aug 2006
    I added the TCM to the bench and the VSS works fine. I'd like to avoid the TCM if at all possible.
    Maybe using an 07 CTS-V calibration would be a better option?
    Aug 2006
    I agree! The only catch is that the project requirements include cruise control...which locks me into the Trailblazer SS E67 ECM.
    Jul 2009
    Do you have the parameters
    - Vehicle Speed Output = RepTOS
    - Wheel Speed Output = Enabled
    - Speed Limiter Source = Calibration
    The pins are the right ones
    The first two parameters are what i needed to change to get the GMPP E67 controller to work along with writing the entire file versus just the cal several years ago
    thanks
    alan
    Aug 2006
    Thanks Alan.
    Are these EFILive parameters or HP Tuners. I cannot find these in the EFILive E67 ECM calibration.
    *EDIT* I don't see these in HP Tuners either. Maybe this is specific to the GMPP calibration?
    Aug 2010
    Quote Originally Posted by alan91z28 View Post
    Those settings are used by default in a Trailblazer calibration ... no worries if you can't access them.
    Regards,
    Taz
    Aug 2006
    Thanks Taz.
    I can also tell you that without the TCM, SAE.VSS always displays 158 mph. I disabled U0101 (Lost Communication With TCM) with no effect on VSS.
    Jul 2009
    yes you're are right Taz i just looked in a reference file for the trailblazer and those are indeed set that way
    mike, i am not sure where these are in EFI Live, in HP they are under the speedo tab and they are set like i referenced on the trailblazer when i just looked
    the other thing i noticed is that there are a couple of weird DTCs that might give you some trouble... try turning off p608 and see if that helps
    what do you see the vss ppm out signal C1 39?
    right now in my 85 IROC with the LS3 type and TVS2300 i am running the GMPP ECM
    - GMPP E67 ECM Part Number 19258268 (pre-loaded with GMPP OS 12638778)
    - GMPP OS 12638778 baseline
    - heavily modified of course, but this is a great OS to start as great MAF range and Fuel (up to 16 g/s injectors)
    i am not sure if they have made these OS available over their web interface yet... it would be great if you could just load up an e67 with it
    What are you using to input a VSS into the ECM? Its going to read a funky value unless you feed it a proper signal, start with that and adjust the speedo params if necessary.
    Ive looked into this a bit when one of the TBSS guys was trying to swap a T56 into his TBSS. He scrapped the project, but Im pretty sure you can run the stock OS and kill the related codes for the TCM.
    Can you post the base file you're working with? And what kind of vehicle is this going in, sounds like a swap (just curious!).
  1. Manual transmission temp PID
    By alwaysinboost in forum General
    Last Post: May 5th, 2013, 03:39 PM
  2. vss sensor function with a manual transmission.
    By monzaaddict in forum Conversions / Aftermarket Parts
    Last Post: October 27th, 2011, 01:59 AM
  3. OS 11352409 for Manual Transmission Trucks
    By DoghouseDiesel in forum Cummins 5.9L
    Last Post: October 6th, 2011, 04:23 AM
  4. Who can tune a Camaro V8 manual transmission for me ?
    By horst in forum E37, E38 & E67 PFI ECM's
    Last Post: September 13th, 2010, 03:31 PM
  5. Transmission TCM programming...
    By serpa4 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 20th, 2007, 04:05 AM
