I'm using a VSS from a T56 transmission and spinning a reluctor on the bench top. The 158 mph value is odd because it is displayed with VSS connected and without TCM connected. Once the TCM is connected SAE.VSS goes to 0 and properly reads VSS.
Calibration at http://www.eficonnection.com/temp/Sm...zerSS_0002.tun. (EDIT - So that's odd. You cannot download this file. How do I post the file?)
The conversion is an LS3 going into an early (80s?) BMW.
.... slow and stock and staying that way!
