Page 7 of 13 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 126
Thread: Public release, March 29, 2012
  1. #61
    Mar 2009
    How do we manually check for software updates now? I found the tab in the V7 tune tool to check for updates with it and found there was an update for it above the first public release I downloaded, but I can't find a way to do it with the V8. I used to go under start, EFILIVE, and then select the check for updates under teh tools tab, but I see that option is no longer available.
  2. #62
    Dec 2006
    Quote Originally Posted by THEFERMANATOR View Post
    I do not think they have implemented the check for updates yet, They turned that feature off.
    I do not remember reading the it was available to use yet.
  3. #63
    As has been discussed in previous thread, we changed software installers on this new version. If you have older software then you must manually uninstall that software first.
    Once the software versions from this thread are installed you can check for updates by doing the following:
    V7
    Go to 'Help' then click the 'check for updates' option.
    V8
    On the main page, the big Icon that says "Install Updates" (probably should say Check rather than install).
    And yes, there has been an update already, so feel free to give it a go.
  4. #64
    Mar 2009
    V7
    V8
    Thanks.
  5. #65
    The main web page links also have the latest versions as well.
  6. #66
    Senior Member 2006Cummins's Avatar
    Sep 2011
    Just updated to the latest public v7.5 and v8 software release, and checked for updates. Firmware: 2.07.26 (Mar 28, 2012). Bootblock: 2.07.04 (Dec 12, 2011). Config files: cummins cm849 (apr 16 2012), options (apr 16 2012). Getting a $502 error (something about script files) when trying to flash using just the v2. Any ideas?
    Thanks,
    Mike
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  7. #67
    Quote Originally Posted by 2006Cummins View Post
    Thanks,
    Mike
    I recommend doing this:
    1. Start the V8 Scan and Tune software.
    2. Open the BBX settings window.
    3. Click on read to read your V2's current configuration.
    4. Select "Format CONFIG File System" from the [Program] button's drop down menu.
    5. Click on the [Program] button to program all required files.
    If that still does not work, use the "Program all Required Data (slower)" option on the drop down menu. Sometimes, within 24 hours of an update (due to crossing the international date line) the date/time stamps on the config files can confuse the algorithm that decides if a file is older or newer than what's on the device. Using the "all" option overrides that algorithm and copies all files.
  8. #68
    Sep 2011
    I will give that a try, thanks.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  9. #69
    Mar 2009
    I tried the method above and it still wouldn't work. I found I had to go into the EXPLORER program and manually delete the files from the options tab and then format and program all to get mine to work.
  10. #70
    Sep 2011
    Worked for me. Thanks!
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  1. EFILive Class in Kinder LA March 3-4th 2012, Duramax and Cummins
    By dansdieselp in forum General (Diesel)
    Last Post: January 8th, 2012, 01:38 PM
  2. Replies: 0
    Last Post: January 7th, 2012, 04:01 PM
  3. Public Release June 03, 2011
    Last Post: July 9th, 2011, 07:59 AM
