Results 11 to 20 of 25
Thread: Truck feels fast for a little while then...................
    Lifetime Member LB72004's Avatar
    Dec 2011
    with your scan tool, connect to your ECM. press Shift & F2 to check for supported PIDs. if it is supported on your rig then they will show up in the PID tab (F8) without the x on them.
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Senior Member JustinD's Avatar
    Jul 2009
    Thanks!
    2001 Chevrolet K2500HD Duramax
    Suncoast SCIV 1056
    Kennedy twin lift pumps
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    A few more go fast/truck pulling goodies!
    Tuned with EFI
    12.65 @ 107 1.71 60'
    Jul 2009
    Had the engine harness swapped and it isn't limiting main injection timing or main injection fuel flow anymore, at least not up top? It runs alot better but I am still thinking something isn't right??? Anyone care to look over these logs and see if anything looks screwy??
    Thanks!
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Jul 2009
    Only thing I see now is B0805 is referencing 6.1-11.9 cells, and when I use an older log where my baro is 14.6 it references the 14.2 cell which is 1.
    This my B0805 with my sensor reading all over the place.
    And this an old log when my baro was staying at 14.6
    Can I just make these values all 1?
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Jul 2009
    It didn't help....
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Dec 2011
    looks like it should be running good from the logs. are you blowing a lot of smoke or is it more of a haze?
    rail pressure seems to be holding. good boost, maybe a little outside its map, but still high for a stock turbo. PW seems about right, 3000~31xx, for about 500 hp.
    the only thing that looked funny to me was the PW & mm3 dropping back down when you hit 80 mph. and going from 9 mph to 58 mph took about 5 seconds. mine can do that with less PW.
    check [B0747 max fuel quantity vs speed], TLIQ & base torque for starters. oh, one other thing that doesn't look right, why is your baro going from 3.6 to 12.8/ should stay fairly consistent with altitude. how is it plumbed in? should be reading outside air pressure, not connected to any of the intakes, etc.
    Jul 2009
    Not stock turbo it has an II Silver Bullet S366, it has no drivability and it rattles a lot, it was suggested that I shim my FPRV, I made 494/956 without it and went 12.65 @ 105 with my stock turbo, but about 3 months after it started to feel slow, I thought maybe the CP3 was weak so when we installed the new charger I got a reman CP3 with an LBZ fpr and it was snappy for about 1 day then it started rattling, and feeling slow and has been doing it ever since, seems that if something is disconnected or Everytime I reflash it it feels fast for a short while until I start to hear it start to get rattley...
    I am here: http://tapatalk.com/map.php?srw4wk
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Dec 2011
    you saying the engine is rattling or the turbo?
  9. #19
    Jul 2009
    Sounds like the engine to me? Sounds more like a power stroke than a Duramax?
    I am here: http://tapatalk.com/map.php?vkgz24
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
  10. #20
    Jul 2009
    Baro is open to the atmosphere it's on the drivers side used to be on a bracket but it broke so I zip tied to the harness
    I am here: http://tapatalk.com/map.php?1exfs0
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
  1. Need help fast truck wont start
    By way2much_01 in forum Petrol / Gas
    Last Post: August 5th, 2011, 10:46 AM
  2. trans feels like slipping after doing a burnout
    By steve40 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 12th, 2009, 03:09 PM
  3. Truck feels sluggish at part throttle
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2007, 05:52 AM
  4. Car feels really flat initially
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: July 26th, 2006, 05:23 PM
