Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Scanning Tutorial
  1. #21
    Jan 2012
    Will do.
    1969 Chevelle
    Stock 5.3, twin PTE62/62's
    E85, No intercooler
    Th400, PTC Convertor, 3.90 Gears
    Meth/Water Injection
    Factory PCM, Wiring Harness
    EFILive,V1, Daily Driver
  2. #22
    Jan 2012
    Ok, do this:
    - unplug your FlashScan from your PC;
    - from the Desktop go Start->All Programs->EFILive->V8->EFILive USB Manager,
    - when the USB Manager comes up, un-install the USB driver, and then install driver version V2.02.04, exit the USB Manager,
    - plug your FlashScan into your PC.
    Okay, I was able to go to Start>All Programs>EFIlive.....but there is no V8. I have V7 or V7.5 choice and neither of those go to a EFI live USB Manager.
    1969 Chevelle
    E85, No intercooler
  3. #23
    Jan 2012
    I did a "search" on my computer and found the EFI live USB manager and uninstalled it as you said. I then installed the version V2.02.04 and plugged the cable back in and clicked okay. The box popped up that said new hardware had been found and was ready to use. However, when I started the car and tried to scan/monitor the same things still happened again. ERR no/cable and Err no ignition detected. Same as before. I do not have V8 though. I have V7 and V7.5
    1969 Chevelle
    E85, No intercooler
  4. #24
    Do you have a different USB cable you can try with...?
  5. #25
    Jan 2012
    No. I can try to get a different one tomorrow. Is it a little weird that it works on the tuning tool though?
    1969 Chevelle
    E85, No intercooler
  6. #26
    Quote Originally Posted by Sinister View Post
    Try this with the engine running and FlashScan connected to both the vehicle and the laptop...
    1. Start the Tune Tool software.
    2. Select the menu option: Flash->Show PCM Info
    3. Click on the [Get Info] button.
    If that works and displays info, then the OBDII connector would appear to be ok while the engine is running.
    If that fails, then it is possible that once the ignition is switched on (Edit: I mean once the engine is running) either power or ground is being lost to the OBDII connector.
  7. #27
    Paul has a good point about power/ground connections in the OBDII socket.
  8. #28
    Jan 2012
    That worked. I had to change the button that said LS1B GenIII 99-08 and then clicked "Get Info" button and it filled in all the blank boxes plus gave a bunch of numbers in the open box below. Looks like that worked. No problems.
    I appreciate the help. I will check this again in the morning. My wife is giving me a hard time coming in and out of the house. We have 4 kids and she is due with number 5 in a couple weeks. Better do as she says. lol. Thanks again.
    1969 Chevelle
    E85, No intercooler
  9. #29
    Jan 2012
    Okay, since it is obvious it wasn't a ground issue, I went and purchased a new micro USB cable. I left the old cable plugged in and then "uninstalled" it. I then installed the version you said and plugged the new cable in. That fixed the problem. It monitored, recorded and didn't shut the car off. Now it is time to figure out how to get the items I need scanned. Thanks again. Problem fixed! Bad USB cable.
    1969 Chevelle
    E85, No intercooler
  1. Condensed Tutorial.....
    By Redline Motorsports in forum AutoCal
    Last Post: May 3rd, 2012, 03:43 PM
  2. Online tutorial??
    By Sparky8370 in forum EFI University
    Last Post: May 10th, 2011, 11:10 AM
  3. WeatherManShawn's Tutorial: can someone look/help...??
    By tatasta in forum Gen III V8 Specific
    Last Post: April 28th, 2010, 02:25 PM
  4. Tutorial
    By Chevy366 in forum Custom Operating Systems
    Last Post: October 25th, 2006, 02:52 PM
  5. LC-1 Tutorial
    By GMPX in forum General
    Last Post: July 23rd, 2006, 12:18 AM
