Page 6 of 18 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 171
Thread: Installing the V8 Software
  1. #51
    Can you open up the V7.5 Tune tool, then click Help->Register EFILive. If your registration details are not populated, then re-enter them (make sure you select the proper License type- unless you have a V1 Personal select Commercial Scan&Tune). There was a problem with an earlier installer erasing the files in the My Documents\EFILive\V7.5 folder so it might have deleted your license file.
    BTW, there is a new public version released just an hour ago. Get it here: http://forum.efilive.com/showthread....-March-29-2012
  2. #52
    Dec 2010
    If I'm still unable to tune, then I will re-register.
    Thanks man
  3. #53
    May 2012
    I have downloaded V7.5 and V8.
    I checked for updates and it says everything is up to date.
    I then tried to rip my stock file off my truck and i get an error code ($11).
    Have no idea what is going on.
    The bootblock and firmware say "go"
    Please help.
    Thanks.
  4. #54
    Quote Originally Posted by Tan70 View Post
    Please help.
    Thanks.
    Have you read through this page:
    http://support.efilive.com/kb_articl...8254-QOGC-9586
    If you send me the trace files as described on that page, I can take a look at what is going wrong.
  5. #55
    May 2012
    Its say it is in demo mode and wont allow me to view what is needed for that
  6. #56
    Have you entered your FlashScan registration details from the blue License card into the EFILive software?
    Once you do that, then the software won't be in demo mode anymore.
    Or if you have your FlashScan device connected to your PC before starting the V7 software the software will not go into demo mode.
  7. #57
    May 2012
    ok it finally read it. do i pm you with what was read or post here?
  8. #58
    If you successfully read out the PCM then there's no need to post it here or send it to me, you're good to go.
    If the read process still fails with code $11 or any other error code, then send me the appropriate trace files. Send them to paul@efilive.com.
  9. #59
    May 2012
    Just went and tried again, this time i recieved an $80 Bootlogger rejected.
  10. #60
    May 2012
    It can't successfully read the pcm.. I get the error $80. And I can't copy the trace to email it to you.
  1. Installing the V7.5 Software
    Last Post: February 9th, 2021, 11:28 AM
  2. Installing new ECM - What to expect??
    By juscruzn in forum Duramax LLY
    Last Post: February 1st, 2010, 09:46 AM
  3. installing drivers for new 7.5.5 v2
    By Adam Calley in forum Gen III V8 Specific
    Last Post: April 15th, 2009, 08:12 AM
  4. Installing new firmware
    By black346 in forum FlashScan V2
    Last Post: March 29th, 2007, 09:02 AM
  5. Installing Custom OS
    By oztracktuning in forum Custom Operating Systems
    Last Post: April 27th, 2006, 09:58 PM
