Results 1 to 10 of 14
Thread: Killed my 2nd ECU. WTF
    Apr 2007
    Default Killed my 2nd ECU. WTF
    For my second ECM....
    Downloaded the latest and greatest. Pulled a fresh tune off the P12 using v8. Opened it up in v7 and changed a few small things. Opened the tune back up in in v8 and simply saved it. Opened it in v8 and downloaded it. It went without issue. Turn the key and nothing. Nothing can communicate with the ECM.
    This is BS. Im so pissed. So now what. Drop some more money on another ECM and license.
    Apr 2007
    Give the ol error $0280
    When I try to download in v8 it go through and says programming. But the timer never starts. This is all it does.
    Executing: C:\Program Files (x86)\EFILive\V8\Config\P12_W.obj
    Virtual Machine Started
    Script Loaded
    Script Verified
    Executing: Boot Loader...
    Checking Data File...
    Erasing: Wait...
    Programming...
    Please: Wait...
    Script exited with code $0101: No data received
    I tried it with a battery charger hooked up and even removed some un-needed fuses to see if it makes it any better.
    The 4th light on the V2 blinks.
    What versions of V7/V8 and what V2 firmware...?
    Apr 2007
    OK it might be something with the voltage. While its trying to program the dash volt meter drops down to 9. Has anyone seen voltage problems give these kinds of issues?
    Apr 2007
    The latest and greatest. I downloaded all of them today. Updated both firmwares as well.
    2.07.04
    2.07.29
    Build 197
    I pm'd Tech Support.
    Quote Originally Posted by Round Rock TJ View Post
    If its flashing about 4 times per second, that indicates the PCM is in dead-poll which just means the calibration is gone (i.e. erased) and has not yet been programmed back in.
    The voltage at 9V is an issue. It needs 12V to program the flash chip.
    Apr 2007
    I got it.
    Script Loaded
    Script Verified
    Erasing: Wait...
    Programming...
    Script finished successfully.
    All I did was download the tune in high speed mode. I had it unchecked because high speed never worked for me in the past on this P12. I thought I would give it a shot and it worked. It took 35 seconds. Im used to the 11 min thing.
    Sorry about the red faces. All I was trying to do was return the car back to stock to sell it. I had to tell the guys to come by another time. I hope I did not scare him off.
    Thanks Guys
    Glad you got it sorted in the end. Unfortunately the older pre CAN bus vehicles can be pretty sensitive to interrupted flashing. If you have ever used TIS (GM's dealer programming system) it always says pull 'x' number of fuses before flashing. Whilst you normally wouldn't need to do that with EFILive nothing is a 100% guarantee with the Class 2 bus vehicles.
    Senior Member Chuck L.'s Avatar
    U find what was causing the low voltage???
    Chuck L.
    CODY Motorsports
    Fuel Injector Service
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
  1. Killed My Truck (funny)
    By GL4787 in forum Duramax LB7
    Last Post: February 4th, 2009, 04:27 PM
  2. KILLED my NEW reman...
    By onewingman in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 4th, 2008, 06:28 AM
  3. I think I killed another ECM...
    By epb091786 in forum Duramax LB7
    Last Post: December 24th, 2007, 12:30 AM
  4. Killed my pcm
    By Boosted GMC in forum General (Petrol, Gas, Ethanol)
    Last Post: December 17th, 2006, 09:02 AM
