Results 1 to 10 of 10
Thread: injector balance rates
    May 2012
    Default injector balance rates
    I am trying to check the balance rates of my injectors because I think I am starting to have problems with them. I have looked all over my efi scan tool and asked on many forums and what most people say to do I can not find. I have no listing of balance rates under my PID tabe anywhere. I have also went under vdt and found where I can shut injectors off but I don't think it is working and I can't find where to read the info from that. I guess I am looking for step by step instructions on how to do this incase I am just doing something wrong. This is very frustrating and it sounds like it should be pretty simple to do. Someone please help.....
    Senior Member Chuck L.'s Avatar
    Question
    Balance rates?? Not sure what you are looking for.
    What issues do you suspect are happening??
    Chuck L.
    CODY Motorsports
    Fuel Injector Service
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    Lifetime Member LB72004's Avatar
    Dec 2011
    what engine are you checking?
    make sure you have the correct ECM selected in the scan tool, then when connected press Shift + F2 to validate the pids. in the list of pids you should see "Balancing Fuel Flow Rate Cylinder #1" though 8. select them and log
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Apr 2008
    Post as much info as to what you are working on. If a Duramax diesel and no Balance Rate PIDs then check this post. Look at my last post in this one.
    http://forum.efilive.com/showthread....ance-Rate-PIDs
    Most important download and install the latest of both V7.5 and V8 software as well as updating the Firmware and BootBlock on the Flahscan V2 if that is what you have.
    If still no balance rate PIDs then exit the Scan app and rename the EFILive directory I mention in that post. Restart the Scan app and follow the steps mentioned to start scanning.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
    Sounds like a diesel topic, I'm moving it to the diesel section...
    May 2012
    Yes sorry it is a 04 gmc lb7 duramax
    Apr 2008
    Just seeing if you got it figured out and what you had to do to get it working.
    Brian
    May 2012
    Yes Brain I got it working. Just had to update my software and had trouble figuring how to do it. But thanks to the people on this site I got it working
    May 2012
    Now my results show me I think I need new injectors.......that sucks
    Apr 2008
    Got to checking old post glad you got it working. To bad on the injectors.
    Brian
  1. LB7 injector balance rates
    By minytrker in forum Duramax LB7
    Last Post: August 24th, 2014, 02:51 PM
  2. How to scan/check injector balance rates?
    By duramax07tmd in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 7th, 2011, 02:50 PM
  3. LB7 Fuel Injector balance rates reading 0
    By StuntHeavy in forum Duramax LB7
    Last Post: July 7th, 2010, 02:03 PM
  4. Cant read balance rates on an 01
    By Dmax15 in forum Duramax LB7
    Last Post: August 14th, 2009, 04:28 PM
  5. Balance rates
    By diesel freak 123 in forum Duramax LB7
    Last Post: April 22nd, 2008, 02:55 PM
