Results 1 to 7 of 7
Thread: Existing V2 adding Cummins support?
    Dec 2005
    Default Existing V2 adding Cummins support?
    I know this had been discussed in the past but is there a path to add Cummins support to my existing GM v2?
    Nov 2010
    As long as its a blue V2, then you can purchase the Cummins tuning and go from there.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Nov 2009
    Yes you can add cummins support to your existing v2, however, only the blue v2 has the hardware to support the 2003-2005 cummins. White and blue v2 will support 06-2009 cummins.
    -Kory
    http://www.PPEI.com/
    Dec 2005
    I currently have the GM v2, the orginal one, it sounds like if I want to tune an 03-05 I have to buy the Blue V2 too, at $800ish??
    Dec 2005
    Assuming this will work to ugrade my existing v2 to add cummins ?
    http://www.efilive.com/index.php?pag...mart&Itemid=54
    Yes, that will unlock the ability to tune the Cummins ECM. That said, since you have a black V2 and not a blue V2, you will still be limited by your V2s hardware to tuning 06-09 Cummins ECMs (should be able to do the later 6.7L ECMs too once support is released for those).
    Nov 2005
    There was a hardware revision in December 2010 to make FlashScan capable of communicating with SCI used on the 2003-5 Cummins. To make it easy for customers to differentiate which type of hardware they have, the FlashScan V2 case changed from Black to Blue when this change was made.
    Black V2's are capable of tuning all GM supported vehicles along with CAN based Cummins vehicles (2006+).
    Blue V2's are capable of everything the Black V2 can do PLUS 2003-05 SCI based Cummins vehicles (when support is released)
    The link provided above is suitable for upgrading both Black and Blue V2's.
    Cindy
  1. Any Cummins support
    By 80superbu in forum General (Diesel)
    Last Post: October 15th, 2018, 02:00 PM
  2. 03-05 Cummins 5.9L Support
    By cindy@efilive in forum Cummins 5.9L
    Last Post: February 7th, 2015, 06:59 AM
  3. Cummins support for us V2 owners?
    By johnasara in forum General (Diesel)
    Last Post: August 28th, 2011, 12:02 PM
  4. Converting existing tunes to dsp5?
    By Pruzinsky14 in forum Duramax LLY
    Last Post: July 26th, 2009, 03:01 AM
