Had a customer that was adamant that he get his original file modified instead of one of mine, I read his file out at TS using my V2, scripted over it, loaded it onto an AutoCal and mailed it off. Once he got the autocal it would get nearly all the way through the write process and error out with a $0340 error which is "Download not accepted". I thought maybe I goobered up the setup on the autocal so I walked him thru loading it with the V8 software - same result.
We went round & round ensuring things were up to date, correct files... etc
Turns out his file wasn't a clean base file (previous programmer) - I changed the vin in the original file that I made the script from to script over his which was a true clean chrysler base file and it flashed right in no problems.
For future reference...
