Ok, I've got my LM-1 set to
.5 Volt -----equals 10 AFR
Set 4.5 Volts --equals 18 AFR (is there a way to check the settings without a cable?)
My wife cleaned out the garage a couple of weeks ago and I'm not able to locate my LM-1 cable or software. Being that I now have a new laptop I'm stuck.
How do I go about creating a calc_pids.txt for this. Or has someone done it so I can just copy and paste? I did it once but it was awhile ago.
I tried using the Tech Edge which has the correct formula of
AFR= {EXT.AD2)*2+9 but my LM-1 is reading a 10.2 AFR and EFI is reporting a 15.5 AFR. Could it be that after sitting for many months my battery in the LM-1 lost its charge and the settings I had in it?
Any help would be appreciated.
Dennis
