Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Started AutoVE Tuning help!
    Senior Member jeff keyuk's Avatar
    Jun 2008
    Default Started AutoVE Tuning help!
    Hi Guys I have started auto VE tuning, Please take a look to see if I am on the wright track,I am using a Fast WB,and I have done everthing the tutorial say's to do,.
    Log_jeff keyuk_AutoVE_Tune8.efi
    Your throttle is not sufficiently steady, the transient filter "Base Efficiency Numerator" is throwing out all the data.
    Also, you need to set your LM1 to 1/6 filtering to smooth out the measured AFR;
    the measured AFR is tending to be rich.
    Jun 2008
    Hi Joe! Thanks for the answer back, I will be more steady with the throttle,Question on the Base Efficiency numerator,In on the map properties,I click on to (Base Efficiency Num.1-LM (factor)-not currently selected). I take it that is wrong,Which one is the one I should of click on to!And in the Data filter 5.00% is to high, As you can tell, I new to this. Thanks again for any help.Cheers Jeff.
    Hi Jeff,
    No worries... post a screenshot of the filter you see...
    Jun 2008
    Hi Joe Not sure how to do a screen shot,but this is what I am looking at in the "Data Filter"
    NAME ( TPS MOVES TOO FAST OR LOW COOLANT TEMP)
    FILTER CONTROL: (Exclude date Frames) and I think that should be [U](Include date Frame )
    and in the FILTER TYPE is ( Changeing mor than 5:00% per 100ms.)
    than I have inthe Filter (Sae.ECT)is changing more than 66.80degrees C.per 100ms.
    Hope this is ok what I just posted to you. I will try and do that screen shot.Thanks again jeffkeyuk@live.ca
    Screenshot, see post #2 or #10 here: Hosting-an-Image
    Find the filter that looks like this:
Name:	BEN filter.png
    if it has a condition for RPM < 2500, delete that condition (highlight it, click Remove, click Ok).
    Jun 2008
    Hi Joe, No luck trying to screen shot my filter data. The printscreen tab seem to not work on my key board???? I have the image editor greenshot,Question Can't you just click on Log file up top to see the filter data Log_jeff keyuk_autoVEtune8 on the first page and see it there.
    When Greenshot is installed it intercepts the PrtScrn key-press and captures the screen (you have to mark a rectangle on the screen using the cross-hairs).
    Your filter may not look like mine... (the filter is not stored in the log file).
  1. Calc. VE Tuning - Newbie getting started
    By blsnelling in forum Gen III V8 Specific
    Last Post: October 5th, 2010, 04:19 AM
  2. looking to get started tuning
    By smslyguy in forum Gen III V8 Specific
    Last Post: November 16th, 2008, 05:57 PM
  3. Need a little help gettin started on COS3 fine tuning. Please
    By nonnieselman in forum Custom Operating Systems
    Last Post: June 11th, 2007, 05:47 PM
  4. 2003 2500HD 6.0L - Started Tuning Yesterday Nice!
    By Black02SS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 22nd, 2006, 10:45 AM
  5. AutoVE tuning Help
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: November 18th, 2005, 11:55 AM
