Are there any tables I need to change in the E38 when going up to the 102mm TB's? I know on the older computers you had to change the ETC throttle area conversion table. Do the E38's have a similar table? If so, what do I need to put in there?
02 Z06, 573/530rw N/A 416, 10.21@136.12.
I don't seem to have that table when I tried to check ? B1650 ?
Thanks again Taz. You the man.
Here is a funny. Forgot to set the table and got half way down the street and hit Reduced engine power. Then it hit me. I would have been sucking with out that table Taz. Thanks again.
