Results 11 to 20 of 32
Thread: When throttle kickdown is not set at 100%
    Quote Originally Posted by FeetDry View Post
    I'm looking for the spreadsheet that has makes the color graph. Is it posted somewhere?
    I copied the PT/kickdown tables into a program called DPlot, and then played with the shading feature... attached is the .grf file if you're interested.
    Senior Member johnmaster's Avatar
    May 2011
    Digging up old but helpful thread, have a hanging 1>2 shift that sometimes requires me to lift in order for it to shift, usually when I am peddling it out of the hole or starting from a roll and on and off the gas to get the tires under control. 100% across the board on the next tune and we'll see if it cleans it up. I like my valvetrain intact...
    Hi JM, if you get it working, post the before/after tunes.
    May 2011
    No Such Luck, did it again last night but didnt catch it in the act. I have a log a couple weeks old, not the same tune as posted but basically the same. here is a log of it doing a full throttle shift good and then missing the shift.
    Note, my set-up is a turbo blow through carb 99 c1500. The TPS I use only goes to 88% when it is at wide open throttle. 30% throttle is very light cruise, 50% throttle is a good hard pulling out into traffic type of acceleration, 85-88ish is wot. I currently have my kickdowns at 100% which should be unattainable but it still acted up last night.
    Problem seems to be rolling hard acceleration or when tires spin out (raising mph on the vss) most likely doing a 1-2-1 shift when I pedal it and get it back to wot. Oddly I noticed delivered engine torque drop to 0 at 5600 rpm, though it should never have been there in the first place (should figure that out for when I raise my shift rpm).
    Any suggestions would be appreciated.
    Hi JM,
    the problem is this:
    your WOT downshift speeds are above the WOT upshift speeds... they should be below (at least 5 mph lower)...
    set D0925-7 below D0910-2,
    set D0930-2 below D0915-7,
    set D0935-7 below D0920-2.
    Same applies to the part throttle downshift/upshift tables (the downshift should be below the upshift at each corresponding throttle position) .
    BTW those WOT upshift speeds are quite low...
    May 2011
    Awesome, easy to fix! I didnt even notice the wot downshift speeds, I did make the upshift speeds low so it would always be satisfied easily and use the rpm for the shift point. Need to sit down and fix a bunch of this stuff, I rushed the trans in and kept changing stuff on the truck and never took the time to hone the trans tune.
    Is it easy to figure out why my torque number drops to zero at 5600, it sent shift pressure down to 43 which will not be good when I start shifting this thing higher...
    Thank you so much for figuring this out for me!
    I see you have all the fuel cut offs set to 5600.
  9. #19
    May 2011
    ahhh-Ha! Awesome again man, that would have taken me days to figure out (if I ever did...). Thank you!!!!!
  10. #20
    Mar 2009
    Hi JM,
    Joe you know I'm in no way trying to step on your toes as you are the master with this stuff but those shift tables he posted are stock. And every truck based 4L80E tune I've ever seen have the downshift speeds higher than the upshift speeds so I wouldn't say that is the issue. Suppose it makes sense too. It can't downshift unless it already upshifted first, correct?
  1. converter unlock on WOT kickdown
    By DURAtotheMAX in forum Allison 5 & 6 Speed
    Last Post: May 21st, 2014, 09:40 AM
  2. how to tune throttle follower and throttle cracker?
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 03:43 PM
  3. No Kickdown?
    By DrX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 15th, 2009, 06:55 AM
  4. Only seeing 84% throttle
    By Scoota in forum Gen IV V8 Specific
    Last Post: November 15th, 2009, 11:04 AM
  5. Trans KickDown
    By Wolfie in forum Gen III V8 Specific
    Last Post: February 25th, 2009, 02:20 PM
