Results 1 to 10 of 11
Thread: Working on Calc.VET tune and getting odd data when logging
    Senior Member Hyper99's Avatar
    Oct 2005
    Default Working on Calc.VET tune and getting odd data when logging
    I have setup 7.5 as instructed and I pulled the CALC.VET in the latest thread about this method. When selecting this PID file and logging data, I get duplicate fields in the DATA section of 7.5.
    There are duplicate entries for a couple of the PIDS, even though they are only enabled once.
    Calculated VE - BEN corrected - the second one has valid data present, the first one stays at 0%??
    If you look at the Dynamic temp fields, they are not really valid values for the label (F) -357 degrees?
    DAT appears in the list twice, the second entry carries the proper Temp value - why is it showing two entries??
    Don't want to use invalid data when tuning, so I need some clarification as to what might be going on here.
    Log file and CALC_VET.PIDS file are attached.
    Any help would be appreciated
    99 Silverado 2500 Extracab Longbed
    33" BFG's - American Racing Rims
    Custom Dual Upper console gauge mount w/Autometer Sport Comp - Pyro, Oil Temp
    Autometer Sport Comp Boost/Vac in Custom Hypersonic Gauge Mount in dash
    LS-1 6.0L w/AFR 205cc Street Heads
    Vortech V2 blower
    42# Injectors
    Comp Cam - Custom Street Grind
    TTS Catback Exhaust
    Innovate LC-1 Wideband O2
    Tune and Trans mods via EFILive V1-V2
    If you're using VE[%] did you enter your engine displacement (Edit->Log File Information, find the tab with displacement, enter it in cc; remember to save log file)...?
    What is the OS id of your tune file...?
    Your GM.DYNAIRTMP_DMA pid is producing the wrong values...
    Can you post your current tune file...
    If that pid doesn't work right, we can edit calc_pids.txt to use your B4901 table for DAT.
    Oct 2005
    Attached are the existing tune, new tune and calc_pids.txt files - with the existing tune is the one with today's date and that was the one that the log was made from. I did miss adding the Displacement in EDIT LOG, Is this something that I need to do each time? The calc_PIDS.txt does appear to have a variable called DISPLACEMENT - can I hard code that just for tuning this truck?
    The existing tune has an OS of 09379910 and a cal of 9374401 - I intend to update to the other tune attached, it is for a 2002 and all the 99 settings that were proven on the truck are transfered. When loading the tune in the truck the Message center always displays "SECURITY".... Is there something I missed when updating? The truck starts and runs fine with the new OS (12212156) and CAL (12212431) but depend on this truck for days I am on call, so I put the old tune back in until I figure this out.
    Calc_PIDS.TXT file attached. Please advise on what you find.
    Thanks for the help
    Vortech V2 blower
    42# Injectors
    TTS Catback Exhaust
    I'll look more closely at your files tomorrow...
    what is the year/mode of your truck (is it the one in your sig...?)
    Oct 2005
    Yes - 99 Silverado
    Thanks!
    Vortech V2 blower
    42# Injectors
    TTS Catback Exhaust
    Hi Hyper,
    I'm sorry it's taken me so long to get back to you I have been utterly swamped...
    Quote Originally Posted by Hyper99 View Post
    If you use [%] units for VE, then yes, before analyzing a captured log you have to go Edit->Log File Information->Vehicle Options->Engine [cc] and enter the displacement and save the log file.
    If you use [g*K/kPa] units for VE, then you don't need the displacement.
    No, leave the reference to displacement() alone, it references the value you enter via Edit->Log File Information->Vehicle Options->Engine [cc].
    If you changed the OS you might have to relink VATS, try this, but first log the various STATExx pids to see if it they give a reason for the security light/display.
    Ok, your GM.DYNAIRTMP_DMA pid doesn't work for your 9379910 OS...
    does it work for your 12212156 OS (it should)(post a log file)...?
  1. Setting up for first log for calc vet tune.
    By Laychut in forum Gen III V8 Specific
    Last Post: April 28th, 2012, 07:58 AM
  2. Calc vet ???
    By Chuck L. in forum Gen III V8 Specific
    Last Post: September 8th, 2011, 01:12 PM
  3. Calc VET
    By pormgb in forum Gen III V8 Specific
    Last Post: August 28th, 2011, 09:39 AM
  4. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 01:20 PM
  5. Replies: 4
    Last Post: June 3rd, 2011, 09:07 AM
