Results 1 to 8 of 8
Thread: No data being recieved//displayed.
    Aug 2012
    Default No data being recieved//displayed.
    not sure how to ask the question.
    1. setup efi, current versions, can watch efi communicate with the ecm with no errors reported
    2. retrieved my 09 lmm stock ecm files, saved.
    3. setup a pid file, created dashboard, 4 gauges.
    4. start the monitoring counter, crtl m to activate gauges.
    no data showing on the gauges. a file is created and saved.
    can run any of the provided files and the gauges work.
    Terry
    Click the record button rather than the monitoring button.
    Aug 2012
    I tried both buttons, the record created a file but no display movements. Tried to play back the file, no joy.
    Did you select pids on the PIDs tab...?
    Post screenshots of PIDs tab and Dashboard.
    Aug 2012
    .Click image for larger version.
ID:	13773Click image for larger version.
    Aug 2012
    Default files created
    here are the files created
    The pids you have selected are external pids (i.e. not pids from your PCM/ECM)...
    i.e. they are pids that the scantool will read from the dyno... (i.e. you have to connect a serial comms cable between your dyno and your V2);
    in order to read dyno pids you also have to read some PCM/ECM pids.
    What year/model/vehicle...?
    Aug 2012
    Thanks for the comments. You can remove this thread as the issue has been resolved. It was "operator error". All is well.
  1. Converting Ford style injector data to data useful to EFI Live.
    By JOHNBOY in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2012, 06:19 AM
  2. Replies: 2
    Last Post: May 2nd, 2012, 11:28 AM
  3. Having some issues with BBR. $0101:No Data Recieved
    By BlackGMC in forum FlashScan V2
    Last Post: October 19th, 2009, 12:48 PM
  4. No ports displayed in the device manager
    By Trippin in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 9th, 2008, 07:35 AM
  5. "UPSHIFT NOW" Displayed in DIC
    By yellowC6ohio in forum Gen IV V8 Specific
    Last Post: May 5th, 2008, 02:44 PM
