Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 3rd Gear TCC locking/unlocking issue
    Aug 2010
    Quote Originally Posted by 1BadAction View Post
    Doesn't appear that I will be able to make it work. OS 12579405
    Upgrade to 2004 truck OS 12587603. You will need to adjust the injector tables - your 2003 truck still uses a fuel return line and fuel rail mounted pressure regulator. 2004+ moved to a returnless system.
    Then swap in the transmission segments from a 2004 Corvette A4 with the same OS (12587603).
    Regards,
    Taz
    Member 1BadAction's Avatar
    Mar 2009
    Quote Originally Posted by Taz View Post
    Regards,
    Taz
    Awesome, this sounds like a plan. Thanks guys.
    2013 1SS/1LE Blue Ray Metallic Camaro - DD
    1991 2500 Suburban - Roller cam'd high compression 454ci BBC tow monster
    1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac
    1984 18' Contender Tunnel/2.4 Merc ModVP
    Cool
    Mar 2009
    Mar 2009
    No going back now...
    Mar 2009
    Up and running based on the suggestion from TAZ (thank you sir!), truck ran fine but felt like I was towing 3000lbs. Besides the inj tables he mentioned, almost ALL of the other fueling tables are different stock V stock, PE mode especially. So for anyone else doing this, make sure you go through all of the engine calibration tables with a fine tooth comb.
    Mar 2009
    Now it's taking a bit longer to crank than it did before. ugh... Any suggestions?
    Mar 2009
    Never figured out this issue, but another issue that came up is the "anti-clunk" clunk reduction built into the engine OS that holds a bit of throttle as you come to a stop. There's no way to turn it off or modify it, and I will not deal with a truck pushing me through a stop light like my TBSS did with it's stock tune. It was a good experiment but I ended up going back to the original OS.
  9. #19
    Aug 2010
    No such thing as a "free lunch" is there ?
    Sometimes changing the OS will require a touch up to the VE & MAF tables - not a problem as long as the injector data is accurate. With a WBO and a free morning this is quickly sorted out.
    This should address the longer cranking you described. If not, and the engine starts better with the throttle opened slightly - then add some airflow via B0102.
    The "push" when coming to a stop and the "anti-clunk" you described can be tuned out via B4307 - the airflow will need to be reduced. Do this in small increments until the vehicle acts the way you prefer.
    A little extra work - but in the end the vehicle should run like it came from the factory - just depends on your comfort level with the software, and how much effort you are willing to expend to keep the TC locked while coasting.
    Regards,
    Taz
  10. #20
    Mar 2009
    No free lunch for sure, lol... I will be working on my WB02 installation this afternoon and getting it sorted out, then try again. I've been looking for an excuse to start working with lean cruise also, hopefully I can pick up a bit of MPG.
  1. 3rd gear flare shift
    By mstordahl in forum Cummins 5.9L
    Last Post: June 5th, 2012, 08:05 AM
  2. 3rd gear t/c lockup
    By whackem04 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 27th, 2011, 10:38 AM
  3. converter locking in 2nd & 3rd @ WOT
    By Superado in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 31st, 2009, 08:27 AM
  4. locking/unlocking issues
    Last Post: July 13th, 2009, 12:32 PM
  5. Locking and unlocking converter in 3rd gear
    By Scott(382-$T$) in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 29th, 2006, 04:25 PM
