Results 1 to 10 of 10
Thread: electric Fans
    Lifetime Member 87gmc's Avatar
    Apr 2004
    Default electric Fans
    Can efilive flashscan actually activate the wire on a 99 Ls1 truck? I have heard of it and thinking of installing ls1 fans on my z71.
    Jul 2004
    Hook up a test light and go driving.
    Apr 2004
    ok if i do the test light is fan activator a positive or negative wire.
    Sep 2003
    Doesnt matter once there is a path to ground the light will light. Bulbs have no polarity unless its an LED
    Quote Originally Posted by John Skiba
    Or just use the bidirectional controls to command the low and high speed fans relays on/off.
    Whether or not the PCM is actually calibrated to command the electric fans or not is a different story.
    PCM switches the outputs to ground.
    With relays (or test lights) one side must go to +12V, the PCM will switch the other side to Ground to turn it on.
    Sep 2007
    Blast from the past! Hi again folks., Finally got my truck running again, and I just installed a set of 2006 Silverado on my 2000 Silverado with the fans connected to the computer. But, it doesn't work. One side is connected to the computer, the other is connected to ground. After reading this, can I assume that I need to have 12V instead of ground connected to the relay? Thanks.
    Sep 2007
    Disregard, found the problem thanks to stroker97k1500 over at PacAudio. I'll be connecting 12V to the relay instead of ground tomorrow, then the computer should be able to control things. Embarassing, but the important thing is that I'll have it working as soon as I fix this wiring snafu.
    Aug 2006
    Quote Originally Posted by Juanmartinez View Post
    How do led lights different from normal bulbs?
    L.E.D. (Light Emitting Diode) A diode is kind of like an electrical check valve. Electricity will only flow one way through them and won't flow if they are hooked backwards. So, If you have power and ground hooked up correctly it will light up. If it is hooked up backwards it will not light up.
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    Also, if the LED does not already have a series resistor, you have to add one to limit the current thru the LED.
  1. Electric Fan Control
    By epb091786 in forum Duramax LB7
    Last Post: June 8th, 2009, 03:35 PM
  2. Electric Fan Problems using pin 33
    By chevy052500hd in forum Gen III V8 Specific
    Last Post: June 6th, 2009, 09:06 AM
  3. Who's converted an '02 6.0 truck to electric fans?
    By HTMtrSprt in forum Gen III V8 Specific
    Last Post: March 9th, 2009, 02:58 AM
  4. PIN out #'s for Electric Fans
    By MN C5 in forum E37, E38 & E67 PFI ECM's
    Last Post: October 13th, 2008, 11:14 PM
  5. Wish List Item - More control over Electric Fans...
    By MrZ71man in forum FlashScan V2
    Last Post: March 3rd, 2008, 02:42 PM
