Results 1 to 8 of 8
Thread: PID's selected but wont show in data tab - HELP!!
    May 2012
    Default PID's selected but wont show in data tab - HELP!!
    All,
    I'm trying to log pids GM.ETCTP1 & 2 along with some other throttle pids to watch voltage and percentages.
    The pids all select but will not show in the Data tab even when connected the to E38 ecm.
    The only thing I notice is that in the units column it does not have a value associated with it (it should be %).. All other pids seem to select and show in data just fine.
    I've updated the software to the latest version and the firmware is also updated.
    I am able to view the GM.ETCTP1 & 2 in the BBx and it shows the data being collected, but when I load that scan file into the Scan V7.5 it will not show those pids or values in the data tab????
    What am I doing incorrectly?
    Any help would be appreciated.
    John-
    Hi John, can you post some screenshots of the PIDs and Data tabs...
    May 2012
    Here are the pid and data tabs from a scan I did with the BBx
ID:	13830Click image for larger version.
    May 2012
    Here is a quick test scan I did.
    I was able to see the TPS 1 & 2 % logging on the V2, but when I load the scan file into Scan 7.5 on the laptop the values are not present as representative in the above screen shots.
    E38_0016.efi
    Thanks for taking the time to help.
    Best,
    John
    May 2012
    joecar,
    What I did was to load the bbx with the pids from V8 (I don't know of another way to do that). I can view the data logging on the BBx...
    When I try to load that file from the SD card onto the laptop it shows I have the pids selected, but no data is shown for those 2 pids.
    I did validate the pids today with Scan 7.5 connected to the E38 but the Data tab still does not show them..
    Quote Originally Posted by Protec View Post
    joecar,
    Its a problem with the V7 PID definition. When a PID is defined with no units it doesn't show up. I'll get it fixed asap.
    Send me an email to paul@efilive.com and I'll send you back an updated file so you can view those PIDs.
    Actually, you can fix it yourself by editing the file:
    \Program Files\EFILive\V7.5\Configuration\sae_generic.txt and making the following change:
    From this:
    Code:
    #Units             Low          High      Fmt Op     Factor       Offset
    *UNM-08-1
     .                 0.0           0.0     0.0   *      0.0           0.0
    To this:
    Code:
    *UNM-08-1
     .                 0.0           0.0      .0   *      0.0           0.0
     %                 0.0         100.0      .1   /      2.55          0.0
    May 2012
    Work nicely....
    Thanks for all the help....
    John
  1. Replies: 1
    Last Post: December 26th, 2011, 02:17 PM
  2. added lc-1 serial PID but doesn't show up on dashboard
    By Bill00Form in forum FlashScan V2
    Last Post: November 19th, 2011, 10:36 AM
  3. cannot get fuel pressure pid to show
    By Cablebandit in forum General
    Last Post: July 25th, 2007, 09:52 AM
  4. Replies: 2
    Last Post: November 30th, 2005, 03:50 PM
