Thread: 02' 5.3l tune questions, visible exhaust, low inconsistent idle
    Member ippielb's Avatar
    Jun 2010
    Default 02' 5.3l tune questions, visible exhaust, low inconsistent idle
    Tuned my truck, basic tune, VE tutorial, basic spark advance, transmission tuned. Just did the knock sensors and front o2 sensors. But the truck still has visible exhaust like condensation in the exhaust it is not coolant. And the idle is very inconsistent. It goes up and down, and along with that the AC clutch kicks on and off all the time even with the air conditioning off inside the truck.
    I have no cats and have turned off cat protection and disabled the MIL.
    I was wondering what one can do to help with the inconsistent idle and the visible exhaust.
    On a side note the truck feels gutless. When I am driving 2nd gear at around 1200rpm and give it some throttle, you can hear the throttle body open but it accelerates like crap. The truck is maintained immaculately, no exhaust leaks, good fuel filter, new sensors, good fuel. I can't figure it out.
    And last, I have two LC-1 I want to hook up into the long tube headers. But keep the narrowbands as well.
    2006 Chevrolet Silverado 2500hd 6.6l LLY Duramax
    NADP Race Transmission & NAPC Built Transfer Case
    AFE Stg 2 Intake Snow Performance Methanol Injection
    FASS 150gph Titanium Series Pump EFI Live
    PPE Race Valve & PPE Fuel Rail Fitting
    BD Manifold 3" AFE Ceramic Downpipe 4" Straight Pipe
    Yukon Grizzly Locker Mag-Hytec Cover & Traction Bars
    Leveling kit & 33" Hankook RT03 18" XD Addict Rims
    HID's all around LED taillights and 3rd brake light
    Autometer Fuel Pressure, Boost, and Pyro Gauges
    Look at:
    - B3608, B3609: set these to zeros.
    - B3616: set this same as 2001/2002 Camaro (65% below 3600, 35% above 3600).
    If you have FlashScan V2 you can connect your two LC-1's using serial comms in daisy chain manner:
    first LC-1:
    SERIAL IN <- terminator plug
    SERIAL OUT -> SERIAL IN of second LC-1
    second LC-1:
    SERIAL IN <- SERIAL OUT of first LC-1
    SERIAL OUT -> null modem adapter/cable -> V2
    note: specifically, a null modem serial adapter or cable is required.
    You can drill/weld new bungs in your long tube headers and run the WBO2's in parallel with the NBO2's...
    or you can use the LC-1's narrow band output to drive the NB signal to the PCM, i.e. the WBO2 installs in place of the NBO2.
    When you have your widebands installed, you can easily get the Calc.VET tutorial accomplished.
    Jun 2010
    I will check those out when i get time. And for the cable from the LC-1 to the V2, does one need those TAQ cables? I will be drilling new holes to put the LC-1's in as well. I want to run both, but i was also wanting to run a AFR gauge. how can i work it so that i can do both?
    The TAQuickness cable is a one-piece null modem cable, this is easier to push thru a hole in the firewall/floorboard...
    some people use the null modem adapter to join the LC-1 cable to the V2 cable, but the adapter has to specifically say "null modem" on it or it won't work.
    Does the AFR gauge run from the analog voltage from the LC-1 (the yellow wire)...?
    Jun 2010
    I will most likely purchase the TAQ cable then for ease and reliability. And i have yet to purchase an AFR, i am thinking about what one i should buy.
  1. 99 ls1 cold air, headers , and exhaust tune?
    By hdsvette in forum Gen III V8 Specific
    Last Post: September 28th, 2010, 05:12 PM
  2. 5.3 LM7 low idle
    By hoff2483 in forum Gen III V8 Specific
    Last Post: March 3rd, 2009, 12:13 PM
  3. Tranny tuning made visible
    By Lennart in forum General (Petrol, Gas, Ethanol)
    Last Post: March 8th, 2008, 12:11 PM
  4. Low Vacuum at Idle - in the tune?
    Last Post: October 31st, 2007, 02:33 PM
  5. Low hanging fruit and other newbie questions.
    By NewV in forum Gen III V8 Specific
    Last Post: December 6th, 2006, 04:04 PM
