Hi guys,
I've bitched in a couple of other threads about this problem and still havent found a way to solve it on my own. I have an 00 C5 M6, running a v3 OS (02030003) Cal version 7.76. I am running in open loop and Mafless, and my IAT sensor is working just fine. The C5 intake sits in the engine bay, so when my car sits at idle in traffic, the temps climb.
I have my VE table dialed in using a wideband for approx 30* IAT. Idling and cruising around near this temp and my commanded AFR matches the actual AFR perfectly. My problem is that as IATs rise, my mixture leans out compared to my commanded AFR. This makes perfect sense, but I need to find a way to correct for this. Right now all I can do is tune my VE to a warmer IAT, but then it goes RICH at lower IATs. I have tried different values in the Open Loop IAT multiplier table (A0014), even maxing out the 50*+ cells to 1.30 and these appeared to have absolutely no effect? I have also tried different blending values (B4901) and even turned the blending off entirely and this didnt help.
I read in somewhere in another thread that the PCM is dumb to the IAT in SD mode. I thought SD mode by definition relied on IAT, MAP, and VE to determine the airflow? How can a PCM calculate the airflow accurately without properly considering the incoming air temperature???
Anyhow, I will keep fiddling around with the aforementioned tables but would really appreciate some guidance. I'm so confused about why I can make huge changes to the A0014 and B4901 tables with zero difference in either direction.
Thanks for any help!
Craig
