Results 21 to 30 of 31
Thread: 4L60 and shift kit
  1. #21
    For the 3->4 shift, raise pressure more... post pic of your 3->4 shift pressure.
  2. #22
    Aug 2010
    3>4 shift pressure can be a horizontal line, if need be - 96 PSI in all cells.
    Regards,
    Taz
  3. #23
    Aug 2012
    Thanks for the reply, sorry i meant 2-3 shift.
    hopefully i've uploaded the file rite?
Name:	2-3 shift.jpg
  4. #24
    Try increasing pressure for the 2->3 shift.
    Also check the following:
    - is your VE table correct (make sure it is not scaled low for any reason).
    - check line pressure by attaching gauge to line tap on LHS of case, observe while driving.
    What 2nd servo piston do you have...?
  5. #25
    Aug 2012
    Can i send you my Tune link (Maybe via Email) to over look my tune/table??
    Using a aftermarket servo maybe a Vet type/large Alloy, not 100% sure deff not standard.
  6. #26
    Quote Originally Posted by VZThunder View Post
    You can pm me your email address, and I'll reply to that.
  7. #27
    Aug 2012
    Hopefully you have recieved my email.
  8. #28
    Aug 2010
    Hello Matt,
    Received your PM - can't respond via PM as I believe this feature isn't active until you have made at least 10 posts in the Forum. Post your tune in this thread, so that myself and others can review it, and perhaps generate a solution.
    Regards,
    Taz
  9. #29
    I received it and I'll be looking at it over the next day...
  10. #30
    Aug 2012
    I'm back... Opening a dead thread again!!matt_vz_thunder TRANSGO Shift Kit_0000.tun
    I've had a mechanical pressure cage on the trans, every gear pressure is around 300psi, strange thing is when reving out in 2nd and near selecting 3rd pressure drops momentarily - selects - then pressures back up and off we go... huge delay. It has heaps of DFCO settings for 3rd would this delay the shift, nill torque manage in any gear?
    Hope my upload worked ok..
  1. vz v6 4l60
    By zrx1200 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 21st, 2008, 11:09 AM
  2. 98 s10 converted to carb but still has 4l60
    By minytrker in forum Vortec V6/V8 Specific
    Last Post: August 30th, 2007, 01:39 PM
  3. Trying to use 4L60-E with 4-barrel carb
    By towline_5 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 22nd, 2007, 07:33 AM
  4. 4l60 going bananas ! (maf sensor?)
    By Boost in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 16th, 2007, 09:48 AM
  5. 4l60 to mn6
    Last Post: March 5th, 2007, 07:33 PM
