Results 1 to 10 of 13
Thread: Tuning 2008 ford f-750 with cummings 6.7, possible?
    Sep 2012
    Default Tuning 2008 ford f-750 with cummings 6.7, possible?
    Tuning 2008 ford f-750 with cummings 6.7, possible? like the title says, can i tune this vehicle with efi live. is the cummings ecm independent of "dodge" or how does this work?
    No, you can't do this.
    I believe I spoke to you on the phone earlier. What ECM is in it, doubt ford is using a dodge ecm? EFI currently supports 06-07 CM849 Cummins Diesel ECM (5.9) and 07-09 CM2100A Cummins Diesel ECM (6.7)
    I did find a place that tunes them but they didnt list what they use. They looked like a 18 wheeler shop.
    Nov 2005
    Some of the details available online don't directly state that the engine/ECM is the same, but it doesn't say that they are different either.
    Perhaps this falls into the same black hole that consumes all the Duramax engines used in a vast array of motor homes????
    In any case, lets find out one way or the other for sure. Can you please PM/email me the VIN from your truck, and if that doesn't work out through us checking, can you please take a photo of your ECM and email it to me.
    email is cindy at efilive dot com.
    Cindy
    May 2012
    I would like to know this as well as I have a couple 6.7 powered F650s that would like a tune. They say CM2100 on the ECM, but the plug is a tad different than the ones used in the Dodge application. I will try and get a couple pictures.
    Tobin
    2006 Ram 2500 5.9 Cummins 48RE
    2008 6.7 Cummins swap in 1997 Ford F250 + 4R100 with PCS Control
    Nov 2005
    Couple of pics would be great. The OP never got back to me
    Cindy
    If they're 2100 ECMs, try to read them out. Should be a pretty easy test, if they read then it would be a matter of mapping the OSs if they're different. If not, then who knows.
    May 2012
    Here are a couple pictures of the ECM on a Ford F650 with the rear gear train motor.
    Tobin
    Nov 2005
    Thanks for posting the pictures. It's not the same ECM as used in the trucks, but I'll make a few enquiries and see how we go.
    Cindy
    Nov 2010
    Cummins Industrial ECM's are different than the Automotive ones.
    Cummins proprietary communication protocol...
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  1. Ford Tuning
    By RNA47 in forum General
    Last Post: March 8th, 2012, 06:39 PM
  2. so now you do cummings
    By ace68 in forum General (Diesel)
    Last Post: October 11th, 2011, 03:21 PM
  3. Replies: 8
    Last Post: February 18th, 2010, 10:30 AM
  4. Ford tuning?
    By nathans1987 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 6th, 2009, 03:06 AM
  5. Ford Tuning
    By Cougar281 in forum Lounge
    Last Post: January 3rd, 2009, 09:43 PM
