Results 1 to 8 of 8
Thread: Copying stock tune. nEED Help!
    Oct 2012
    Default Copying stock tune. nEED Help!
    Okay so i had a lot of problems copying the stock tune, it kept freezing up when it was copying and when it finally went all the way through and copied a window popped up that said "integer overflow" i dont know what to do at this point.
    What year/model/vehicle...?
    V7, V8, or V2...?
    What V7 build version...?
    What V8 build version...?
    What V2 firmware version...?
    Screenshots...?
    Oct 2012
    2007.5 Lmm duramax
    v2 and using 7.5 tune tool
    What is the firmware version running in your V2...?
    What is the V7 software build version...?
    Oct 2012
    its the 211 build and its the V7.5.7 version
    Can you try reading it using the V8 software?
    Also, please make sure the firmware is up to date in your FlashScan device. You can do that by clicking on the [Check Firmware] button in the main screen of the V8 software.
    Oct 2012
    The flash keeps freezing. Is there anyone could call me or give me a number I could reach someone who knows what the heck they are doing. It's buggin the crap out of me and I haven't even tuned the thing yet! Just trying to copy this ECM
    The flash keeps freezing means (to me) that you are programming the ECM. Yet you say you are only trying to read the ECM, so I'm a bit confused.
    If you could please provide some quality information then I can help you figure out what is going wrong.
    What firmware version is in your FlashScan device?
    Have you tried using the V8 software instead of the V7 software to read the controller?
    If you have tried the V8 software, there will be a trace file of the attempt(s) in the folder: \My Documents\EFILive\V8\trace.
    Please find the trace file that matches your attempted read (based on the date/time in the trace file's file name) and send it to me at paul@efilive.com.
    Until I've seen what's in the trace file, speaking on the phone to you won't be much help.
  1. Replies: 10
    Last Post: July 7th, 2012, 07:52 AM
  2. copying file to v2
    By electricblue in forum FlashScan V2
    Last Post: August 24th, 2011, 08:28 AM
  3. Copying tune to different VIN
    By kbbrett in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 23rd, 2007, 06:55 AM
  4. Copying Tables to Different OS
    By Kiwi Ed in forum General (Diesel)
    Last Post: August 8th, 2006, 07:35 AM
  5. Copying parameters from one tune to another??
    By Wasted Income in forum General (Petrol, Gas, Ethanol)
    Last Post: February 15th, 2006, 05:46 PM
