Results 1 to 9 of 9
Thread: 60e to 80e segment swap on COS
    Jan 2012
    Default 60e to 80e segment swap on COS
    Im swapping the 60e in my 01 Sierra to a 4L80e and need the segment swap. what do I need to do to get the 80e tables in my tune. running cos 01270003. Thanks for any help.
    2011 Cadillac Escalade ESV. BTR 218/224 .553/.553 110LSA. Built 6L80 with 278mm Circle D 2800 stall converter.
    What GM OS did you start with before that COS...?
    Do you have a 4L80E file with the same GM OS...?
    If you can't find one, then you have 2 options:
    - modify the transmission subharness (add relay, repin 2 pins) so the 4L60E segment can drive the 4L80E trans.
    - swap OS to 12212156 (and copy your tables over), swap the 4L80E segment from a 12212156 file (which is easily found), apply COS 02020003.
    Jan 2012
    My stock OS was 12208322. I dont know how to look up the same OS with the 80E file
    Feb 2012
    The 2001 Silverado 6.0 Litre tune on tunefieldepot is OS 12208322 with 4L80
    Go with a 12212156 OS and seg swap it to an 80E, kill 2 birds with 1 stone.
    Jan 2012
    How would I go about doing that? Im picking the trans up tomorrow and dropping it off at my builders place.
    Find a 4L80E 12212156 file, and copy all of your old tables into the new file (two instances of tunetool open, for each table do copy/paste with labels, take your time and do it right, takes about 2-3 hours, when done, engine should run as good as it did on the old flle).
    And then do the COS upgrade.
    Jan 2012
    Awesome. Thanks for the info. The trans in at my builders getting looked at. Souldnt be too long before I get it back
  1. How do you do a segment swap?
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 8th, 2012, 08:18 AM
  2. M6 to 60e swap with COS3 & SD
    By 2ktransam in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 22nd, 2009, 09:16 AM
  3. M6 to 60e swap with COS3 & SD
    By 2ktransam in forum Custom Operating Systems
    Last Post: June 22nd, 2009, 09:13 AM
  4. A4 to M6 segment swap help
    By Aloicious in forum General (Petrol, Gas, Ethanol)
    Last Post: March 23rd, 2009, 10:24 AM
  5. Segment swap...Q's???
    Last Post: November 6th, 2007, 07:14 PM
