Page 7 of 16 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 154
Thread: Improving shifts via the ECM
  1. #61
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    THANKS JOE
    i had to reload paint as it must have got deleted
    OK guys here is the screen shot
    is it just the first 0.0 column in the TORQUE MODEL (highlighted ) that is upped by 15% ,OR the whole table
    thanks
Name:	coefficient Table A20 RPM airflow.png
  2. #62
    Lifetime Member Rhino79's Avatar
    Jul 2006
    Whole table
    Head Calibrator
    Gwatney Performance Innovation
    Jacksonville, AR 501-982-2102
  3. #63
    Aug 2008
    thanks
    Rhino,
    i'm assuming that it would be best to start with THE stock T43 tune ?
    as the one i have in at the moment has had shift pressures and shift times , etc altered
  4. #64
    Yeah, go back to the shock tune. You can change the shift times down a bit still or it will always battle to get them back to what it thinks it wants.
    The other thing to consider, if you don't want harsher shifts at lower RPM's, don't mess with the torque table down there.
    As for the Cam degree axis, for the Commodore it doesn't matter, just change all columns.
  5. #65
    Aug 2008
    thanks for that
    the other thing im trying to find is the GM.TRQENG in efilive scan dash page , i have it loaded in to the v2 from explorer>BBX but i cant seam to find it in the list when adding pids in the dash pages ?
  6. #66
    Aug 2008
    well i upped the torque model 15% in the E38 and it didn't do any thing that i can feel to my MODED a6 tune ??
    if you select NO in the torque management T43 on wot up shift does that cancel out the the torque table ?
    6l80e
  7. #67
    Aug 2008
    UP DATE
    just for fun i reloaded the STOCK T43 tune with the + 15% in the the ecm WOW its just as good as the modded tune
    and with the torque management set to NO in D9401 AND NONE in D9412 and D9414 its better then the modded tune a lot nicer shifts AND THE MANUEL SHIFT is way better it has got some real feel now
  8. #68
    Member scottcmb's Avatar
    Aug 2011
    Have you played with the "Minimum Final Timing" in the ecm tune to go with your TCM adjustments yet?
    2008 HSV GTS LS3
  9. #69
    Quote Originally Posted by [email protected] View Post
    UP DATE
    Eventually you got there then ;-)
  10. #70
    Aug 2008
    yes i just thought it would make more off a differance to the moded tune so i went that with that first ?
  1. How mcuh should be A/F between shifts ?
    By wesam in forum Gen III V8 Specific
    Last Post: September 20th, 2010, 07:14 AM
  2. spikes during shifts??
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: January 9th, 2009, 05:02 PM
  3. Shifts to soft from 1>2... HELP!
    By LS1FREEK in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 26th, 2008, 12:10 PM
  4. ETC help on shifts please.
    By azzhauler in forum General (Petrol, Gas, Ethanol)
    Last Post: November 8th, 2006, 11:20 AM
  5. Replies: 0
    Last Post: February 6th, 2006, 10:12 AM
