Results 1 to 10 of 10
Thread: Tuning for more MPGs
    May 2012
    Default Tuning for more MPGs
    I'm still learning, so bear with me... trying to tune a friends truck for maximum MPGs. It's a bone stock, right down to the air cleaner and exhaust, 2006, Quad Cab, 3.73 geared truck running 265/75R16s.
    Since I'm still learning, I started out with the "gift tune", backed off the main injection quantity a little, increased the timing in the 1500-2200RPM range a litte and this is where I'm at.
    One thing that concerns me is the balance rate of the #1 injector, it seems to level off at -2.2
    Looking for feed back...
    Nov 2010
    You need to log Cummins PID's...you were logging what looks like GM PID's.
    I ask my customers to log these PID groups....please select the green check marks in order from BOTTOM to TOP. You will get a error message but ignore it.
    Relog with those PID's and the help will come.
Name:	new pid list.png
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Lifetime Member 06redram's Avatar
    Jan 2011
    Les I am trying to set up my PID Group it will not let me get all 4 of the group with green check marks.
    Nov 2010
    Yes that's the error I was talking about...continue on and it will not log a couple parameters but will log the necessary ones...
    Took me a while of trial/error to get the order and number right to keep the right ones and have the unnecessary ones cut off.
    Les Szmidt
    2007 5.9 Dodge Ram
    Nov 2010
    You MUST select from BOTTOM to TOP!!!
    Les Szmidt
    2007 5.9 Dodge Ram
    Jan 2011
    Yes your right I see them, but how you get all 4 check marks to stay green not one red and three green. Will it correct to all 4 green after I log
    Nov 2010
    Not sure..try it and see.
    Les Szmidt
    2007 5.9 Dodge Ram
    Jan 2011
    It works Les big thanks
    Nov 2010
    If the OP logs with those pid groups...help will be given.
    Les Szmidt
    2007 5.9 Dodge Ram
    May 2012
    I just haven't had time to really play with this truck...
  1. loss of MPGs after valve adjustment???
    By LB72004 in forum Duramax LB7
    Last Post: January 4th, 2013, 08:02 PM
  2. Replies: 7
    Last Post: June 1st, 2012, 04:26 PM
  3. Single Injection Event for mpgs
    By Trapper in forum Cummins 5.9L
    Last Post: December 7th, 2011, 07:11 PM
  4. 08 Silverado 5.3 Tuning, tuning-spark/pe mode/
