Page 8 of 18 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 171
Thread: Installing the V8 Software
  1. #71
    Junior Member Black_Tiger's Avatar
    Nov 2008
    Try changing the Windows regional settings to US.
    i just try that,
    but the same Issues .
    Power Maker Dyno
    www.pm-dyno.com
    Middle East
  2. #72
    Oct 2004
    The regional settings being set to a non English local is the only known way of getting that error to occur. Similarly, setting regional settings to English (United State) has worked in all other cases. Please do double check that you correctly made the recommended adjustment.
    Andrew
    EFILive Crew
  3. #73
    May 2011
    hi all, may I get advice to updatemy v8. I seem to need build 191. anyone have it so I may catch this thing up.Thre only version I see is Download is ---- EFILive V8.2.1 Build 203... it will not update I get a 403 error? or something.. Thanks, Caleb
  4. #74
    Quote Originally Posted by rubber View Post
    Post a screenshot.
  5. #75
    May 2011
    Default V2 Update gets me blue screen after 8 & 7.5 update/ reinstall ARGGHHHHHH!!
    Post a screenshot.
    HI Thank you for your time and reply Joecar I (cant get the pic.. )now I have v 8 installed , and 7.5 , both the latest.. Upon hooking cord & V2 I am getting blue screen on v2 scanner.. tried loading usb manager... IT loads, and I get options to install either 2.02.04 or 2.08.14 . (I am in admin mode..) I get error code 740: the request operation requires elevation. NOW What Please Anyone
  6. #76
    See post #24 here: brand-new-V2-crashes-my-HP
    No need to dual boot.. you just have to hit f8 just after the bios boots and a menu will appear.. choose disable digital signature enforcement and continue to boot.
    Download the driver set from moates.net and you will be able to use it no problems. be sure to NOT boot with the usb connected or it will crash...
  7. #77
    Requiring elevation: your admin login does not have high enough privileges.
  8. #78
    May 2011
    hi joecar the only guy on the computer is me and if i rt click i have all options checked for privileges in acct. how can I fix ? ??
  9. #79
    Oct 2004
    The 740 error is related to UAC. See THIS knowledgebase article
    Andrew
    EFILive Crew
  10. #80
    May 2011
    rebooted .. updated, this time all good.. (reboot x3 then admin wt heck)... 3rd try a charm thanks..
  1. Installing the V7.5 Software
    Last Post: February 9th, 2021, 11:28 AM
  2. Installing new ECM - What to expect??
    By juscruzn in forum Duramax LLY
    Last Post: February 1st, 2010, 09:46 AM
  3. installing drivers for new 7.5.5 v2
    By Adam Calley in forum Gen III V8 Specific
    Last Post: April 15th, 2009, 08:12 AM
  4. Installing new firmware
    By black346 in forum FlashScan V2
    Last Post: March 29th, 2007, 09:02 AM
  5. Installing Custom OS
    By oztracktuning in forum Custom Operating Systems
    Last Post: April 27th, 2006, 09:58 PM
