Results 1 to 4 of 4
Thread: ISS transmissions
    Mar 2007
    Default ISS transmissions
    Does anyone know when the intermediate speed sensor (ISS) started to be added to the 4 speed autos? Either 4L60/65/70E etc... or the 4L80/85E's? There is probably a good chance it wasn't done all at once, but was curious as to when it started. Car information is nice, but would also like to know when the trucks started getting them.
    I'm trying to better understand what years of ECM / TCM combinations are better than others. I think that I read for AFM (active fuel management) to work, you had to have a transmission that had an ISS. Not sure if VVT also required it or not too.
    4L80E and 4L85E always had the ISS (input speed sensor).
    4L70E and later 4L65E also have it.
    4L60E and early 4L65E did not have it.
    (I can't tell you which years).
    I don't think ISS is a requirement for AFM, and I know VVT is not required for AFM... but I don't know the details.
    Mar 2007
    joecar,
    Thanks for the reply. I figured that this would be a hard bit of data to decipher out. Kinda suprised that the 4L80E's always had one... I guess this might lead to another question, maybe I am just confused about what's inside the transmissions these days.
    Is there just an Input Speed Sensor and an Output Speed Sensor, or is there an Intermediate Shaft Speed Sensor too? Maybe the Intermediate Shaft Speed Sensor is just in the 6 speeds?
    4L80E cross section shows ISS and OSS (they're shown on top of the case by drafting convention, but they're actually on the side of the case):
    4L60E cross section shows OSS (being VSS) is read from the reluctor on the output shaft:
    The ISS on the 4L65E/70E is read from an extra set of dog teeth on the input shaft (at the pump/stator support).
    I'm not sure about the 6L80/90, I'll have to look in the HMTG.
  1. E38 4l60e non iss possible?
    By 400ss in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 6th, 2012, 03:20 PM
  2. E38 + 06 4L60E no ISS Posible?
    By 400ss in forum Gen IV V8 Specific
    Last Post: September 2nd, 2012, 02:28 PM
  3. E38+T42 w/ older 4L60E w/o ISS
    By vectorbundle in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 16th, 2012, 06:30 AM
  4. t42, no ISS
    By miguelc in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 4th, 2011, 08:20 AM
  5. E38 with T42 for 4L60E (no ISS)
    By gmh308 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 24th, 2008, 01:19 PM
