Page 7 of 13 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 127
Thread: Installing the V7.5 Software
  1. #61
    Post a screenshot.
  2. #62
    Feb 2010
    never done that, what is the easiest way to do it, thanks
  3. #63
    See post #10 here: Hosting-an-Image
  4. #64
    The registry setting that the latest installer uses to figure out if an old version of the software exists is:
    \\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Cu rrentVersion\App Paths\EFILive_Tune.exe
    It then looks at the version number of the exe that the registry key points to, which will usually be either:
    \Program Files\EFILive\V7.5\EFILive_Tune.exe (on Windows 32 bit systems)
    or
    \Program Files (x86)\EFILive\V7.5\EFILive_Tune.exe (on Windows 64 bit systems)
    It then looks inside the *.exe file(s) and to determine their version numbers. And based on the version number it finds it may complain that an old version exists and should be uninstalled first.
    It will only do that once, because after you've installed the latest version all future updates can be installed over the top of the existing install without uninstalling first.
    Either way, if you delete the folder(s) referenced by the three registry keys, then the new installer should not complain that an old version of the software exists.
    i.e.
    \Program Files\EFILive\V8
    or
    \Program Files(x86)\EFILive\V8
  5. #65
    Feb 2010
    I finally got it done, thanks for all the help, john
  6. #66
    Jul 2013
    Hi Guys, Any help at all?? I have read this whole forum. Tried uninstalling/ re installing on 2 laptops now. one windows 7 and a windows 8. I have deleted the regedit and still no luck. Same issue on both laptops. all updates done in V8 as well. Sorry if this is not in the right section.
    Error report generated by EFILive at 20:23:33 on Jul 31, 2013
    Error code: ERR_WIN 0/0
    Cannot open file "C:\Windows\system32\config\systemprofile\Document s\EFILive\V7.5\User Configuration\calc_pids.txt". The system cannot find the file specified
    EFILive Version: 7.5.7 (Build 235)
    Platform: Windows NT
    Version: 6.1 (build 7600)
    Processor type: Pentium 1296MHz
    Directories
    Temporary Cache: C:\Windows\system32\config\systemprofile\Documents \EFILive\V7.5\Temporary cache
    Logged Data: C:\Windows\system32\config\systemprofile\Documents \EFILive\V7.5\Logged data
    Customers: C:\Windows\system32\config\systemprofile\Documents \EFILive\V7.5\Customers
    Configuration: C:\Program Files (x86)\EFILive\V7.5\Configuration
    Exported Data: C:\Windows\system32\config\systemprofile\Documents \EFILive\V7.5\Exported data
    Images: C:\Windows\system32\config\systemprofile\Documents \EFILive\V7.5\Images
    Sounds: C:\Windows\system32\config\systemprofile\Documents \EFILive\V7.5\Sounds
    Maps: C:\Windows\system32\config\systemprofile\Documents \EFILive\V7.5\Maps
    Pids: C:\Windows\system32\config\systemprofile\Documents \EFILive\V7.5\PIDs
    Virtual Dash: C:\Windows\system32\config\systemprofile\Documents \EFILive\V7.5\VDash
    Print Reports: C:\Windows\system32\config\systemprofile\Documents \EFILive\V7.5\Print reports
    Bug Reports: C:\Windows\system32\config\systemprofile\Documents \EFILive\V7.5\Bug reports
    Connected: No
    Auto connect: No
    Scan OBDII info: No
    Error retries: 1
    Retry delay: 10
    Message throttle: 0
    Most recently used VIN: 1G1xxxxxxxxxxxxxx (Note: 1)
    PCM information
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Stream-Slow scan mode: Unknown
    Stream-Fast scan mode: Unknown
    Maximum dynamic packets: Unknown
    Most recent communication with vehicle:
    Report ID: 175530 (Note: 2)
    Notes:
    (1) The VIN sequence number is not required for this report and for your privacy it is NOT included in this report.
    (2)The report ID is a checksum of the report text and is used to verify the integrity of the report.
  7. #67
    Hi RM,
    Quote Originally Posted by Rick Martin
    in the scantool do this:
    Edit->Properties->Folders and look carefully at the field for User Configuration... it should be identical to the path preceding calc_pids.txt in that error message...
    click Browse and browse to that same path and click Ok;
    if the path is identical (you browsed to it and set it), then check that your Windows login account has privileges to access (read/write) files/directories located within system directories.
  8. #68
    Actually, look at the spelling of " \Document s\ " vs "\Documents \"
    ( see the position of the space before vs after the "s" )
    Directories
  9. #69
    I think those spaces are just an artifact of copy/paste between EFILive's error report screen and the forum. I'm not sure why it happens.
    See image below for an example.
  10. #70
    ah, ok... ( I thought I was onto something )
  1. Installing the V8 Software
    Last Post: April 18th, 2022, 11:39 AM
  2. Installing new ECM - What to expect??
    By juscruzn in forum Duramax LLY
    Last Post: February 1st, 2010, 09:46 AM
  3. installing drivers for new 7.5.5 v2
    By Adam Calley in forum Gen III V8 Specific
    Last Post: April 15th, 2009, 08:12 AM
  4. Installing new firmware
    By black346 in forum FlashScan V2
    Last Post: March 29th, 2007, 09:02 AM
  5. Installing Custom OS
    By oztracktuning in forum Custom Operating Systems
    Last Post: April 27th, 2006, 09:58 PM
