Okay Guys I have done a few F-Bodies with some help and never had a issue. I am trying to run a 4L80e from RPM Trans in a 2007 TBSS. Engine runs fine having difficulty getting the trans set up to work correctly. I have a issue it seems no matter what I try.
Here is the stock file from the Truck if anybody has tune I can seg swap or something they can help me with on this that woudl be great.
I am running the adapter Harness from Transcentral.com that should convert everything signal wise.
Thanks guys2007 TBSS T42 Reread.tun
