Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: External AD and TEMP inputs
  1. #21
    Is this still true? As I pressed the initialize and calibrate trying to work out why I was logging 1 value on fs but another on the gauge.
    Yes, you must supply ground and 12V to the vehicle connector at the base of FlashScan to power the A/D circuits. The 5V supply from the USB connector is not enough.
  2. #22
    Well I managed to recal it via usb on my desktop and my bench dc converter. Much more accurate even with the pos plx.
    It did however only calibrate just ad1.
  1. External AD and TEMP inputs
    By Blacky in forum Do you want to be a Beta Tester?
    Last Post: May 23rd, 2009, 01:49 PM
  2. Resolution of V1/V2 A/D inputs?
    By Garry in forum External A/D inputs
    Last Post: January 3rd, 2009, 11:56 AM
