Thanks. You make a good point, honestly if you had a touchscreen laptop the effect would basically be the same. You do lose effectiveness in tablet mode for tuning but with the keyboard out I use my fingers to navigate and select and manually the numbers so it is much faster than a non-touch screen. Tablet mode is more handy than I originally even thought just yesterday I was using it to reference a PDF wiring harness in tablet mode while working on something and it was very easy to just hold in one hand and read like a book.
EFILive and every other windows programmer works off a set of preconstructed elements to build from to save time. Eventually the new stuff will trickle down to every application we use, but scaling like I demonstrated in the vid would be awesome!
edit: you have no idea until you try it how fast and easy web browsing is with your fingers (touches save button)
