Results 1 to 10 of 11
Thread: Newbie question - dashboard problem
    Lifetime Member Rich Z's Avatar
    Default Newbie question - dashboard problem
    And things were going so good......
    I wanted to look over my log files I scanned today, but something has gone haywire in my scanner program. I'll open the log file, and the scan screen will show the dashboard name fine at the bottom of the status display, but neither of the dashpages are displaying. Tried just loading in the dashboard, but that gave me the same result.
    Pic is attached to this post.
    Well, that's just great. So how do I recover that custom dashboard I created? Even more important, how do I view those log files I created today?
    Now the odd thing is that some of the MAPs I played around with ARE still visible when I click on the selection letters for them.
    So what did I do wrong? This isn't the end of the world, but I sure as heck don't want to keep on making this kind of mistake if I can help it.
    CorvetteFlorida.com
    2002 Corvette Z06
    427 RHS block built by LME
    STS rear mounted twin turbos
    It nearly died on the operating table, but I'm bringing her back.
    Nov 2006
    shft+ctrl+o
    In the scan tool:
    edit> properties> startup tab
    select the .vdf and check the always load dashboard file box.
    LC-1 WBO2
    shft+ctrl+o
    In the scan tool:
    Yes, I saw that option, but it doesn't do me any good if the dashboard is apparently corrupted. I can't call it up even manually selecting to open it. I don't know what trashed it and am concerned that I might do it again. So is there a way to recover a trashed dashboard?
    Thanks....
    CorvetteFlorida.com
    2002 Corvette Z06
    Can you open the dashboard file (6th button from the left)...?
    Well it pretends to open, but the dashpages are blank. I tried opening it from the menu selection as well with the same results. The MAPs are there, so apparently it is reading something related to what I was playing around with on that dashpage. The only thing I can recall I did that might have blown up the dashboard was that I didn't realize that I can't change PIDs (I think that's what it was) on a dashpage while a log file is open. Could that have blown it up?
    CorvetteFlorida.com
    2002 Corvette Z06
    Try to create a new dashpage (add gauges/charts) and save to a new filename.
    You can change a dashpage with a log open.
    Well, I know I can just go ahead and create a new dashboard/dashpage, but I sure would like to know why my current one just got corrupted. Are there any known "no-no" things I might have done to cause that? Any way to recover a corrupted dashboard/dashpage?
    Thanks...
    CorvetteFlorida.com
    2002 Corvette Z06
    Rich,
    Zip up the VDash folder and email it to me.
    Rich,
    Sent! I also attached one of the log files that fails to load the dashboard pages I set up.
    Thanks.
    CorvetteFlorida.com
    2002 Corvette Z06
  1. Scanner Dashboard Problem...need a little assistance
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2009, 09:20 AM
  2. Can someone help me with this newbie problem
    By Slow73 in forum Gen III V8 Specific
    Last Post: May 26th, 2009, 07:55 PM
  3. Having problem with dashboard.
    By Brian1 in forum General
    Last Post: December 30th, 2008, 10:44 AM
  4. Newbie Question - No Dashboard Response
    By CVs06Tahr in forum Gen IV V8 Specific
    Last Post: February 20th, 2007, 04:16 AM
  5. Newbie...dashboard-B not updating
    By PewterC5 in forum General
    Last Post: July 30th, 2006, 02:14 AM
