Results 11 to 20 of 57
Thread: Vortec Calc VET Auto Tune, Final Answer!
    Quote Originally Posted by EagleMark View Post
    That's what I have been doing, I have several now, but in the end only one can be used by the software and it must be calc_pids.txt correct?
    Here is one you did AFR Calc viewing in that I added three from the Calc VE Tuning tutorial. See if I got it correct?
    Yes, correct, calc_pids.txt.
    After *CLC-00-002 there is *CLC-00-00... looks like this be *CLC-00-003.
    How about this, I simplified by re-using the newer VE calculation (CLC-00-003 becomes CLC-303):
    Dec 2010
    Actually it was a total mess, I was on my tuning laptop using Notepad. Never have 2 or more instances open in Notepad! I blew it. That file was all messed up as you noticed. It's still missing CLC-00-003... and look in *PRN - Parameter Reference Numbers at number 3? It's 303, shouldn't that be down lower in order?...
    I use EditPad on my shop laptop. What do you use or recommend?
    Notepad++ is my go-to free editor for basic things like this and minor programming. Might do what you want plus has a tabbed interface.
    Dec 2010
    That works for free as well as my 2005 paid for version of EditPad which needed a paid for update!
    Since *CLC-00-003 was missing in that, you replaced it with *CLC-00-303 which is what I need here I just moved it.
    Is it acceptable to Comment out a entry? Look at:
    *CLC-00-273
    # *CLC-00-273
    calc_pids_TEST.txt
    Yes you can comment out like that;
    it is not complete tho, you will have to provide CLC and PRN entries for CALC.B4901.
    Dec 2010
    Think I got procedure right. Not sure I have all correct changes done, going to test.
    Understand that I have experiance with sytax from HTML. CGI etc... and learning how/what/why these entries work.
    Dec 2010
    That calc_pids file may look good but it does not work, one entry twice. Going back to start again.
  9. #19
    Dec 2010
    You have to rename the original file.
    Also note that when editing calc_pids.txt you must ensure there are at least two blank lines at the end of file.
    I think in your case the correct pid to use is GM.AFR_B, it is intended for the LS2... post some logs of this.
    Here's a log and pid list with GM.AFR and GM.AFR_B. NOTE: While in vehicle data shows as N/A for GM.AFR. In log it shows as 0.00. GM.AFR_B works in vehicle and log.
  10. #20
    Dec 2010
    Guess what happens if you get all the right PIDS and calc_pid file correct?
    It works!
    At this point I'm not sure which tutorial I followed, but the corrections for fuel and MAF are being done Closed Loop with MAF sensor hooked up in one log!
  1. Auto VE or Calc VET or Auto Maf?!?!
    By Nver2loud in forum Gen III V8 Specific
    Last Post: October 23rd, 2012, 05:08 AM
  2. Cannot get the PID's for either Calc or Auto VE table
    By ippielb in forum Gen III V8 Specific
    Last Post: May 31st, 2011, 02:09 PM
  3. Replies: 1
    Last Post: October 24th, 2006, 06:54 AM
  4. More idle table questions (answer and win a smiley)
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2005, 06:58 AM
  5. a few questions to answer...any help appreciated
    By The Alchemist in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2005, 10:52 PM
