Results 11 to 20 of 26
Thread: Error $5 (analog wideband logging)
    Member rumblebox's Avatar
    Nov 2010
    Have you does this:
    more info: Setting-up-a-FSV2-from-scratch
    Yes, use that calc_pids.txt, and follow the Calc.VET thread (is this your intent...?).
    Don't be discouraged... it simply is a matter of the learning curve.
    Version: 8.2.1 Build 203
    firmware is 2.07.35
    yes but with analog, since i never got my serial to work.
    | 2000 firebird | LQ4 | LS3 top end | 226/231 .600 .602 114 | TCI 3500 | 3" x-pipe under-axle | BMR everything |
    Which analog wideband...?
    in that calc_pids.txt you will have to modify (using Notepad) CLC-00-110 to read as follows (using LC-1 as example):
    Code:
    *CLC-00-110
    factor             0.5           1.5       .4  "{GM.EQIVRATIO}*{CALC.AFR_LC11}/14.7"
    Nov 2010
    i did that and it still wont record.
    Those screens indicate that dditionally you need to select the mentioned pids in the More Info boxes (CALC.PE in screen 1, CALC.DAT in screen 3).
    Temporarily, disconnect the wideband's analog cable from V2 and see if the error in screen 2 goes away.
    Also, mention of CALC.PE tells me you have the older calc_pids.txt file (since the newer file changed this to CALC.CL).
    Which wideband do you have...?
    Were you not able to get it connecting with serial comms...?
    Quote Originally Posted by rumblebox View Post
    I can't log any data after altering calc.pids to use an analog WBO2 for CALC.VET.
    Please see this thread.
    http://forum.efilive.com/showthread....light=loopback
    Because you are using the analog/external PIDs and deselecting them is not an option, you will need to create a loopback link for AD1 to force the A/D counts for AD1 to be zero.
    Then you'll need to hook up the wideband to AD2, and use the AD2 PIDs for wideband logging.
    It is fixed in the next update. That update was due out earlier this week but some last minute problems appeared in final testing and they are still being fixed.
    It may be another week before it is ready.
    Nov 2010
    LC-1. i never got it to work serially. and i can't get the BBX to read the analog either. i only see it on the scan tool (before it stopped working completely)
    Nov 2010
    ok i'll try this.
  9. #19
  10. #20
    Hi rumblebox,
    I took the liberty of renaming this thread.
  1. Ls1 Logging error report
    By Tre-Cool in forum Gen III V8 Specific
    Last Post: December 7th, 2012, 05:49 PM
  2. How do you take a Snap shot of the screen
    By scottcmb in forum General
    Last Post: April 8th, 2012, 08:54 AM
  3. Truck dies randomly, screen shot attached
    By thunder550 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2008, 03:08 PM
  4. Error Report.
    By horsehaulin in forum FlashScan V1
    Last Post: June 5th, 2008, 10:59 PM
  5. EFILive Screen shots as requested by HPT
    By Blacky in forum Tips and tricks
    Last Post: January 7th, 2006, 12:37 AM
