Page 8 of 10 FirstFirst ... 678910 LastLast
Results 71 to 80 of 92
Thread: EFILive V8.2.1.202 and V7.5.7.211 June 22 Update is Available
  1. #71
    Senior Member Behold's Avatar
    Apr 2010
    The V8 Scan Tool software will be available in the next update. Some of the more interesting and important features of the new Scan Tool software are:
    1. Ability to search the log file (forwards/backwards) for user defined points of interest (e.g. "Knock>0 and TPS<20").
    2. Easy to use data filters.
    3. Fully integrated calculated PIDs - no more manually editing the calc_pids.txt file.
    4. Insanely fast load/display times. V8 loads a 300,000 frame log file (3 hours of E38 logging) in about 2-3 seconds. V7 takes over a minute to load just 100,000 frames.
    5. OpenGL support for even faster chart display (http://www.opengl.org/)
    6. More accurate chart data display - shows all peaks and valleys no matter what zoom level is used.
    7. Documented log file format to allow easy read/write file access to third party applications.
    8. Copy/Paste data to Excel.
    I am hoping to have a pre-release ready this week. It was supposed to be last week but some problems were uncovered during testing and they are still being fixed.
    I'll try and post some screen shots later today (if I get time)...
    WOW.... You guys have been busy!!!! Well done. Will look forward to it. Anything making scan better is a step many will love as its a major part of tuning.
    Thanks Antony
    Holden Commodore GTS - LS1 5.7
    12 rib Crank Driven Vortech V2 Centri Charger (Intercooled) 9 PSI.
    LS6 Intake
    LS6 Heads
    YT 1.7 Roller Rockers
    BTR Dual Spring with Ti retainers
    BTR Hardend 7.400 Push rods
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    PCM LS1B with 512KB Running COS5 v01290005
  2. #72
    Yesssss on the Scan tool! At SEMA 2011 Donna was saying you were hard at work on it, glad to see its almost ready!
    Are the late 2012 and 2013 E78 OSs going to be included as well as some new E39 OSs in this release?
  3. #73
    Apr 2007
    Wow. That sounds great Paul. I can't wait to see it and use it. Great job.
  4. #74
    Dec 2006
    Can't wait for this update
  5. #75
    That's not a typo, I really have been working on the V8 Scan Tool for that long :( (longer actually).
    The V8 Tuning Tool is looking pretty cool as well but its not quite as far advanced as the Scan Tool yet.
  6. #76
    Good job
  7. #77
    thanks for the update paul
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
  8. #78
    Yep I know, I also know that good software takes lots of dev time. If you need a tester just let me know, I was doing SQA for a company here in Seattle for a bit.
  9. #79
    Senior Member WyoFreeride's Avatar
    Sep 2011
    Default Re: EFILive V8.2.1.202 and V7.5.7.211 June 22 Update is Available
    Will the pre release be a release candidate like previous versions or just for the beta team?
    2010 Dodge QCSB 6.7 Auto
  10. #80
    Jun 2011
    This is wonderful news, thanks for the effort you put into bettering an already great product!
    Lee
    Reiff Diesel
  1. Public Release Update June 06, 2011
    Last Post: June 20th, 2011, 07:12 AM
  2. BBL installer update: June 12, 2008
    Last Post: June 22nd, 2008, 07:57 AM
  3. BBL installer update: June 12, 2008
    By Chevy366 in forum FlashScan V2 BB Logging
    Last Post: June 13th, 2008, 10:37 AM
  4. June V2 update
    By jfpilla in forum E37, E38 & E67 PFI ECM's
    Last Post: August 13th, 2007, 11:09 AM
