Results 1 to 10 of 14
Thread: Lmm 2008 Savana Support?????
    Jan 2011
    Default Lmm 2008 Savana Support?????
    I was just wondering the vans are dsp capeable thanks for the help.
    Feb 2012
    would't see why they would't be same motor same computer thats what you wire up to.
    Just some guy
    No sorry they are not, the Van used a specific OS that we had some troubles getting DSP5 to work with.
    Feb 2012
    good to know what other vehicles that have duramax's are not supported.
    Just some guy
    Feb 2007
    FYI, you can supposedly move a few wires around and flash a pickup tune into the van ECM.
    Feb 2012
    so could you just pull the ecm and bench flash it with the truck tune and not have to deal with the wires? could be easier for some people that did not want to cut into them.
    Just some guy
    Quote Originally Posted by dieselguy9311 View Post
    Sure but thats not the problem, if you can read/flash the ECM with a van tune in the truck then the OBDII comms are just fine. Its the OS and the pinout on the ECM thats the problem. It sounds like if you swap the pinout on a van to match that of a truck, you could full flash a truck OS and use that.
    Im just hearing of this now so I have no idea if it works, thats just what I took away from JoshH's post.
    Feb 2012
    ok i got ya. thanks
    Just some guy
    Nov 2005
    The 2008 Savana Van is supported for tuning. They are not supported for our Custom Operating system to allow 5 position switchable tuning.
    We offer tuning of 2001-2010 Duramax vehicles as listed here http://www.efilive.com/index.php?opt...148&Itemid=147
    Cindy
    Feb 2007
    I've never tried it, but that is my understanding from what I've read from someone who did. Now that I think of it though, it was an LBZ rather than an LMM. I'm not sure it would work on an 08. On an LBZ, there aren't many wires to change. I studied the pinouts from our 06 van and compared to a pickup of the same year, and there were just a handful of wires, maybe 7 or 8.
  1. P0606 stalling engine on a 2008 LMM
    By Mitco39 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 6th, 2012, 04:12 PM
  2. 2008 Cobolt SS support
    By minytrker in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 28th, 2009, 12:28 PM
  3. support for 2008 GMC Sierra V6 2wd
    By camcojb in forum E37, E38 & E67 PFI ECM's
    Last Post: October 28th, 2008, 03:29 PM
  4. 2008 LMM support?
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 9th, 2007, 11:56 PM
  5. 2008 Corvette LS3 support added
    By GMPX in forum Gen IV V8 Specific
    Last Post: August 12th, 2007, 01:32 PM
