The kPa you saw on top of B0101 would be the units of the MAP axis.
Uploaded the new tune. My LTFT's now range from -3 through 1. They are all 0 when cruising at a steady speed. They used to idle at -11 and -9. What more will change with the wideband involved? Open loop tuning?
Wideband will help you nail PE fueling (high load and WOT).
