The latest EFILive software is now available as a pre-release to EFILive customers. This software is still being field tested and may contain undiscovered faults that may cause the software to fail.
Do not use this pre-release software in a production environment or where failure cannot be tolerated.
Download here:
http://download.efilive.com/Software...e_06_Setup.exe
Before installing and using pre-release 06, please read through the posts for pre-release 05 here:
http://forum.efilive.com/showthread....Pre-Release-05
Important Information:
Firmware
- You must manually update the firmware in your FlashScan and AutoCal devices using the firmware option in EFILive Explorer.
- During the pre-release, the firmware version will remain at V2.07.35 (the same as the current public release). That allows customers to easily revert back to the current public release firmware if this pre-release firmware causes "show stopping" problems.
- You can determine which firmware is in your device by the firmware date.
Pre-release 06 firmware has a date of Feb 04 2013,
Pre-release 05 had a date of Jan 31 2013
The current public release has a date of June 22, 2012.
The Cummins switchable tune (CSP5) feature is not included in this pre-release.
The DPF/EGR restrictions for US based customers are not part of this pre-release.
Bug Fixes:
- Many bugs that have been reported over the past 6 months have been fixed in this release. If you have reported a bug but discover that it has not been fixed or has only been partially fixed in this update, please report the bug again in this thread.
Known Issues:
Please post issues, questions, clarifications (large or small) in this thread.
As issues are reported and confirmed they will be re-posted as "Known Issues" below.
- When charts are configured to use OpenGL hardware graphics acceleration the PID caption fonts can sometimes be rendered incorrectly. (fixed in RC1)
- When charts are configured to use OpenGL hardware graphics acceleration the charts are sometimes not rendered at all until the mouse cursor is dragged into the chart area. (fixed in RC1)
- Attempting to BBL an ECM/TCM pair (or possibly even just a TCM by itself) will result in the error $0281 "No Data Received" error. (fixed in RC1)
- Attempting to unlock an AL5 (Allison 5 speed) controller will cause the controller to become re-locked with a random key. (fixed in RC1)
- Changing a chart's font size, style or name, then attempting to discard changes when leaving the chart editor will not discard the font changes. (fixed in RC1)
- When clicking on the [Config] button in the Scan or Tune windows, the Property Editor opens on the property group instead of on the first item in the group. (fixed in RC1)
- Application Violation Error occurs when closing the Scan Tool window if the following is performed: Enter odo in the PID search text box, expand the Enhanced PIDs group, highlight and delete odo from the search box, close the Scan Tool window. (fixed in RC1)
- Audible and visual alarms not working in BBL mode. (fixed in RC1)
The EFILive Development Team
