Results 1 to 7 of 7
Thread: Wrong ect in tables but correct in scanner and gauge???
    Jul 2010
    Default Wrong ect in tables but correct in scanner and gauge???
    I made this post last week about ignition advance http://forum.efilive.com/showthread....ird-low-timing
    I found the problem but not the cause all of the ECT tables are pulling from the 140c value even though scanner and gauge are showing 100c mainly b5910 and b5913
    it also looks like the IAT values are incorrect pulling from the 35c values when scanner shows 1c which would be correct based off temp in dyno room day of log.
    I am using the link feature to find these values. The math checks out that my timing is based off of the incorrect temp.
    If anyone can help I would really appreciate it.
    Thank you, Dale
    Hi Dale,
    interesting...
    post some screenshots.
    I see the same values in the scantool charts/gauges as the tunetool axis...
    check that the scantool Data tab shows the same units as the tunetool table axes;
    Also, what V7 software build version are you using...?
    Jul 2010
    Thanks Joe, I got the scanner straightened out ect and iat were set to f in the data tab. but still cant figure out the timing. going to log some other timing pids now. I really cant see where the advance reduction could be coming from?
    Timing is hard because there are so many tables... and some of them may have not been discovered/reverse-engineered as of yet.
    Apr 2011
    Default Re: Wrong ect in tables but correct in scanner and gauge???
    This
  1. Correct IFR tables for LS3/LS7 injectors in Gen III
    By SweetS10V8 in forum Gen III V8 Specific
    Last Post: August 13th, 2018, 07:27 AM
  2. Replies: 2
    Last Post: January 20th, 2012, 02:35 AM
  3. correct me if i'm wrong...
    By SPRAYED07 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 27th, 2007, 11:59 AM
  4. ECT Boost tables inop
    By killerbee in forum Duramax LLY
    Last Post: February 17th, 2007, 01:24 PM
