Actually you don't want to select flash scan Auto cal only you want Cummins cm2100 ECM. Flash scan auto cal only is for when no vehicle is connected
ohhh ok so for my 08 6.7 i select cm2100 ECM?
i basically need a step by step on how to find out what OS my truck is so i can get a compatible FACTORY tune file. all i have done so far is register my V2 now from there i do not know what to do im told to plug it in in scan mode but then what and where do i go to look for the info i need?
Connect the V2 to the truck and your computer. Open the scan tool, turn your key to the on position, click on the green button on the top left of the screen, select CM2100 for your controller, put a check in the box for automatic transmission, then select OK. Once the scan tool fully connects, you will see you VIN on the bottom of the screen. Just to the right of your VIN is the operating system in your ECM right now.
ok thanks! now one other question i have is will i risk my PCM crashing if im flashing in a factory tune provided by another member with the V2? reason i ask is because the truck currently has an
edge tuner installed and EFI Live made the sticky about flashing in trucks with previous tuners that were returned to "stock" and them having corrupt "stock" files. so what should i do here? i can set my edge to the stock setting but then if i reflash my PCM with this new factory tune that someone gave me will i be risking damaging my PCM?
If you post up your current operating system, I'm sure someone on here will be more then happy to give you a clean stock file. I do alot of factory flashing with a factory scan tool. I'm sure I will have yours with the PTO high idle via with the cruise control enabled.
Have you put your edge tuner back to stock and removed it?
07.5 Mega stock
00' EX-Cab MFI
ok so what i did was read my PCM using the scan/tune program all i did was read it not save the file because no need to if im not going to keep it but i did get an OS number 11620807!
I have several good stock files with that OS if you need one still, shoot me your email.
2010 Dodge QCSB 6.7 Auto
