Results 1 to 5 of 5
Thread: Cal Flash for T43 causes ECM to reboot.
    Dec 2007
    Default Cal Flash for T43 causes ECM to reboot.
    While flashing a T43 calibration in, about 5 seconds in the ECM reboots - or it does the same thing it does when EFI Live reboots it - the ECM - after a reflash - the relays do their stuff and the fuel pump cycles.
    Build 211 on 7.5.7. Anyone else experience this. Never happened on previous versions. Flash goes through to end ok.
    Cheerz.
    been doing it for me for over 6 months. but apparently only happens when using v7.5 to flash.
    News to us (well, to me anyway).
    Does it happen to any year model? Paul can test this on he' 08 if needs be.
    my ve is an 07, does it on my brother 06 and my dad's 08.
    does it to the ecu during flash. the ecu itself doesnt reboot but all the dash cluster, aircon etc does a reset like it does at the end.
    Ah ok, it's probably the modules on the Single Wire CAN bus resetting, not the High Speed bus we are flashing on.
  1. T43 wont full flash
    By 68sstt in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 31st, 2012, 07:28 PM
  2. T43 Cal File
    By berrelauto in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 16th, 2012, 03:35 AM
  3. Cal-Flash
    By 2006Cummins in forum Cummins 5.9L
    Last Post: January 20th, 2012, 05:37 PM
  4. ecm will not reboot after dsp flash
    By House in forum Duramax LB7
    Last Post: March 30th, 2011, 08:35 AM
