Results 1 to 5 of 5
Thread: 2002 Ecotec 2.2 liter basic questions
    Jun 2012
    Default 2002 Ecotec 2.2 liter basic questions
    To start I have a V2 and I've done a good bit of v8 tuning but I'm curious about 4 cyl support.
    I'm looking to purchase a 2002 cavalier engine, harness, and ecu (p11 I assume) for a hotrod project.
    Before purchasing I would like to confirm that I can flash it with a manual trans tune, disable vats, and possibly a few MIL codes. The p11 doesn't seem largely supported but can I perform these basic changes?
    Thanks,
    Ryan
    The 4cyl files I have (all 2 of them) from 2002 are P08s, they look just like a LS1 PCM.
    You can definitely do VATS and codes. I know full flashing isnt supported on these PCMs, so if you want to flash a manual tune you'll need to use a Tech II or buy a PCM that is from a manual vehicle.
    Jun 2012
    Thanks for the response. I wasnt sure if the car is in fact a P11 but I think I'll grab the eng and harness from the yard, a computer off ebay and then repin as necessary. I'm just glad I dont have to use a PassKey bypass box or something to get around VATS because I've seen them fail before.
    Thanks,
    Ryan
    Sure thing, if you can grab one from a manual then you should be able to wire it up, kill VATS, kill codes, and be on your way. Let us (me) know how it goes!
    Jun 2012
    Sounds like a plan, it will probably be a week or so before I get to pull the engine but I should be able to get it running on a stand in short order.
  1. I have some basic safety questions if someone can help.
    By dodgeram5-92500 in forum General
    Last Post: August 7th, 2012, 03:28 AM
  2. 2000 to 2002 OS to COS sanity check questions
    By Slowrc in forum Custom Operating Systems
    Last Post: November 13th, 2011, 11:31 PM
  3. E38 Basic Questions
    By Matt68 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 7th, 2011, 06:52 AM
  4. 5.3 liter 2002 suburban
    By x MadMAX DIESEL in forum Vortec V6/V8 Specific
    Last Post: December 30th, 2009, 05:27 PM
  5. Replies: 0
    Last Post: October 8th, 2008, 01:01 AM
