Results 1 to 7 of 7
Thread: Use Vin Number to get an OS??
    Senior Member auspeed's Avatar
    Jul 2010
    Default Use Vin Number to get an OS??
    I have found a service that allows me to convert an holden Vin number & it provides the calibration the car should have..
    Is there anyway to work out what OS a car has if I know the calibration #?
    I'm not aware of a register that shows what calibration relates to what OS.
    I'm trying to have tunes pre-built before the car arrives...
    Is it like this: http://tis2web.service.gm.com/tis2web
    when you enter the VIN it tells you the id's of all the calibrations including the OS id.
    Jul 2010
    yep that's the one... e38's give OS but LS1B's dont appear to.. they give a cal id
    You wont be able to have tunes pre-built for incoming cars unless you use Tis2Web and flash a new PCM/ECM and use that. This just tells you the latest OS for that make/model/year, it has no idea what's actually IN the car now.
    Do you see something like this:
ID:	14721 Click image for larger version.
    Jul 2010
    well i was thinking I could use a pre-built file and use the compare & update function or make a script to update the OS in the car...
    Just looking for some time saving....
    Jul 2010
    on your second screen shot i only get the engine calibration number 9357744...
Name:	15-03-2013 6-56-26 AM.gif
  1. Changing the VIN Number
    By Behold in forum General
    Last Post: January 9th, 2016, 08:48 AM
  2. Vin Number Change LML
    By Biodiesel66 in forum General (Diesel)
    Last Post: March 5th, 2013, 05:54 PM
  3. I have no VIN number
    By Tuned55 in forum FlashScan V2
    Last Post: September 21st, 2010, 05:31 AM
  4. my scan tool keeps removing my vin number
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2007, 03:24 AM
  5. holden vin number
    By MICK in forum General (Petrol, Gas, Ethanol)
    Last Post: December 28th, 2005, 08:54 AM
