Results 1 to 7 of 7
Thread: Unsupported 2012 Camaro V6 TCM
    Jun 2010
    Default Unsupported 2012 Camaro V6 TCM
    im having same issue but with the t43 file on a 2012 camaro v6
    Have you updated to the latest software releases?
    Jun 2010
    well i check for updates and it shows none.. im runing build 211
    RC1 is available HERE and will not show up automatically. You MUST manually upgrade the firmware on your V2 as well using EFILive Explorer. In the RC1 thread, Zach from StarLite Diesel put together a great document on how to do this.
    Jun 2010
    still no luck with me.. running OS 24264142
    now im on build 222 on v7 and still no luck
    Mmm, ok, I thought that OS was in the latest installs, sorry.
    I would never recommend doing this normally, but in this instance it will work.
    Using Windows Explorer, locate the file '24261871.calz' in the T43 folder -
    \Program Files\EFILive\V7.5\Calibrations\T43
    Make a copy of it (right click on the file name and select copy), right click again and select 'paste'. This should create a new file called '24261871 - Copy.calz'.
    Now just rename the copied file '24264142.calz'.
    It's just lucky both those OS's are identical enough that it will work.
    Then try reopening your trans tune.
    Jun 2010
    GMPX that worked.. thanks for ur time.. ill dial in the trans and then go from there.. really appreciate your help
  1. 2012 Camaro V6 help
    By 05gmcsierra in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 2nd, 2013, 02:57 PM
  2. 2012 Camaro SS
    By jah81592 in forum Gen IV V8 Specific
    Last Post: March 19th, 2013, 12:07 PM
  3. Unsupported PCM '12 LFX Camaro T43
    By Boost in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 15th, 2013, 01:10 AM
  4. 2012 Camaro V6
    By Rhino79 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: February 13th, 2013, 01:55 AM
  5. 2012 Camaro LFX
    By sycraft in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: November 7th, 2012, 09:37 AM
